Old 24th July 2005, 01:48 AM   #1
andy2 is offline andy2  United States
Default Fighting mid-bass hum
I've just finished building Troel's Acapella SE
http://www.troelsgravesen.dk/diy_lou...pella%20SE.pdf
Initially, there is quite a bit of mid-bass hum (or resonance) which makes double-bass and male voice sound kind of boomy. So I decided to put some stuffings right behind the driver and it helps a bit. There is still some left but it is much better now. On some recordings, this is not a problem but on some other recordings, I can feel it is very bothering.
My other problem is that the bass is a little lacking. I have to turn the volume all the way up to get deep and strong bass. The bass driver is an Seas 8in . The cabinet volume is about 42 liters. Is there any way I can boost the bass? My room is 14 x 20 feet. Can an 8in driver provide bass for this room size? the bass is a third order low pass that has no attenuation.
Also, I am suspecting the bass hum is due to internal standing wave. Do you know of a way to brace the cabinet to get rid of internal standing wave? I don't think my cabinet flex. I don't have any measurement equipment but when I place my ears right next to the cabinet walls (don't laugh), I really don't hear any hum. The hum comes right from the driver membrane.
If you look at the cross-over for the speaker, it uses a rather elaborate xover topology. Tweeter and mid uses 4th order with quite a few resistors too. I feel like the music lacks microdynamic. The 4th order certainly helps keep distortion in check but I think it robs the music of its inner beauty. For example, I don't feel the music as much as I did with the Living Voice speaker I used to have. Guitars don't quite have the sparkle that I expect. Ideally, you want some air and bloom around the instruments but I don't feel it here.
I'll email Troel about it. I'll post the picture once I can get a hold of a camera tomorrow.
Old 25th July 2005, 03:42 AM   #2
Here is the first version so far.
http://www.geocities.com/hai_vu1/AcapellaCab.JPG
Here is the rear view
http://www.geocities.com/hai_vu1/CabinetRear.jpg
Here is the inside of the cabinet. I think I made a mistake of not providing a couple of verticle braces. This may partly explain the standing wave at around the midbass which is causing a pronounce hum. I put some stuffing right behind the driver which helps quite a bit.
http://www.geocities.com/hai_vu1/RearNoStuffings.jpg
Old 25th July 2005, 06:08 AM   #3
just another
wintermute's Avatar
Hi Andy,
Just a quick question. Is this hum present when there is no music playing?? or is it just a fuzziness to the sound when playing music?
I'm wondering whether the problem is not with your speakers but with your amp, could be a case of the amp being fine with your old speakers but doesn't like these ones...... just a thought
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 26th July 2005, 03:10 AM   #4
The hum only comes on when playing. It's not really a hum but a pronounce midbass boost -- to much of it though.
I put an extra layer of stuffings right behind the driver and it helps a lot but still on some recording its still there.
Old 26th July 2005, 03:35 AM   #5
just another
wintermute's Avatar
Hi Andy,
I just had a look at the original design and it looks like you have deviated from it quite a bit, Is the volume of your cabinet the same as the original cabinet??? what about the vent, from the picture of the back it looks like you have a very large hole in the back.
My guess would be that your cabinet tuning for the woofer is not correct.
you said that the cabinet volume is 42L, have you simulated this to see how the response curve looks?
Tony.
Some of my photos
Old 26th July 2005, 05:12 PM   #6
Originally posted by wintermute
Hi Andy,
Tony.
As for the port, it is a flare port with quite a large opening but the internal diameter is 3in. which is pretty close to 72mm indicated in the original design. The port lenght is about 220mm but the hum still there when I closed the port. I will try to shorten the port to about 180mm.
It's not really a hum but more like a pronounce upper midbass lift on certain recordings. On others, I really don't here it.
As for the cab volume, it is about 42L -- maybe a litter larger (about 44L) but not by much.
I don't have any simulation tools so anyone knows how the bass will sound if I make the cabinet a little smaller?
Old 26th July 2005, 11:54 PM   #7
just another
wintermute's Avatar
Don't try shortening the port, if anything it should be a bit longer.
I got the specs for your woofer from seas web site and modeled it in unibox. It's not too far off the mark, graph attached.
In the next post I will show what will happen if you shorten the port to 180mm
Tony.
Some of my photos
Old 27th July 2005, 12:04 AM   #8
just another
wintermute's Avatar
here is what happens when you reduce the port length to 180mm
note that the response peak goes up by another db.
Two things I can think of that may be giving you problems.
1. The close proximity to the rear of the driver of one of your braces. you may be getting reflections off it messing up the sound.
2. This is a rear ported design, if you have it too close to the wall you may be getting a bass boost. This may not be just because of the rear port, the speaker may have baffle step compensation in the crossover, and if so and you place it too close to the wall the compensation may be too much.
Tony.
Some of my photos
Old 27th July 2005, 03:17 AM   #9
Hi Tony,
Thanks for the graphs. I thought that shorten the port in effect would reduce the Fb frequency therefore tighten up the bass.
Of course you probably know it better than I do.
As for your comment of the braces that might be causing the problem, I do see a lot of design with vertical brace right behind the driver so I figure it is not really a problem.
Do you think the side panel is the problem? They don't have any braces in themselves but I'll try putting a few on them.
Or do you think the cabinet is actually a little bigger than it should be?
Old 27th July 2005, 04:55 AM   #10
just another
wintermute's Avatar
Well I'm only going off the modelling program but I think it is the other way around, shortening the port increases the box resonant frequency.....
I did a simulation in speaker workshop (quasi butterworth) to see what it thought was the best cabinet volume, it came in at about 50L (one of the things I don't like about unibox, is it won't necessarily recommend a good starting point).
Anyway I modeled it in unibox with at 50L and it looks a little better than 42L so if anything your box is a little smaller than optimal, reducing it further will not help IMO.... if you change the volume you will need to further change the port tuning as well, and will probably end up with a slightly higher F3.
here is the graph.
Tony.
Some of my photos
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
fighting germanium noise? space-cake Instruments and Amps 8 20th December 2006 08:54 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.11600 seconds (86.03% PHP - 13.97% MySQL) with 12 queries
