felt on baffle
felt on baffle
Old 21st August 2001, 05:23 AM   #1
zach is offline zach
I've heard how much of an improvement felt around tweeters can be, but what about using it to cover an entire baffle? The aesthetics of this seem somewhat questionable, but I think nice black felt would be ok. Any input is appreciated.
Old 22nd August 2001, 12:53 AM   #2
Super is offline Super  United States
Send a message via AIM to Super
The use of felt was mentioned in a previous post called "Material Covered Baffles." I don't think that using the felt would produce any negative effects. It can help diffuse and break up energy thats traveling across the front baffle. Somebody mentioned that this design was used in certain Vandersteen speakers, and probably others.
Old 22nd August 2001, 04:24 PM   #3
tvi is offline tvi  Australia
tvi's Avatar
The Duntech speaker used felt on the baffles of aall their models, and John Dunlavy had a paptent on baffles with acoustically absorbent materials on them.
<center>United States Patent <a href="http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1='4167985'.WKU.&OS=PN/4167985&RS=PN/4167985">4,167,985</a>
Dunlavy September 18, 1979
Speaker system</center>
Abstract
A speaker system in which at least one driver is mounted on an enclosure and is adapted to radiate sound waves outwardly from said enclosure in response to an input signal. A sound absorbing material is disposed on at least a portion of the outer surface area of said enclosure to reduce the effect of diffractions and reflections of said sound waves relative to said enclosure.
<center>Regards
James</center>
Old 22nd August 2001, 10:58 PM   #4
GRollins is offline GRollins  United States
The Rogers LS-3/5A was doing the same thing years before that patent was issued. Also, I think the Dahlquist DQ-10 had some felt around some of its drivers. I'm sure there were probably others, as well. I'm curious as to how they managed to get around 'prior art' considerations to get that patent.
If I can squeak some time, I'll try to take a look at the patent and see if they've got something else going on.
Anyway, felt/foam/whatever works well for that purpose.
Grey
Old 23rd August 2001, 10:55 AM   #5
Sawzall is offline Sawzall
Default DQM's for sure did
have some sort of "felt" - actually standy upy fabric which was supposed to cause less diffraction. This was early 80's, and covered all of the front of the speakers.
So hard to see this patent either still out there, or valid at any point. But given the current state of patents, who knows? People are patenting stupid stuff just to show how stupid the system has become - pen lasers as cat toys for example.
Old 30th January 2003, 12:43 PM   #6
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The LS3/5a has a square of 1/2" square section felt around its tweeter.
I've been rounding the edges of my baffles (1" radius) and covering them with felt since 1981. I also cover the front plate of the tweeter. The effect is to clean up the off-axis response and reduce lobing. Oh, and it looks pretty. There are other colours than black, you know.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th January 2003, 01:26 PM   #7
On Hiatus
SY's Avatar
felt on baffle
Grey: USPTO doesn't do a very good job of finding prior art. Normally, all they search is patents, not commercial disclosures or usage nor textbooks. In theory, it's the duty of the applicant to disclose such art, but that often doesn't happen. Patents get granted, lawyers get rich. A goof-up like that from USPTO nearly put my company out of business a few years back.
From what I understand, Dunlavey wisely did not try to initiate any litigation on the basis of that patent- it would have resulted, IMO, in the patent's invalidation.
I don't often say, "The Europeans do it better," but clearly their system of making applications available to the public for comment is a much better way of filtering out stuff like this- competitors have much more of a motivation to find prior art than civil servants.
Old 30th January 2003, 06:24 PM   #8
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
felt on baffle
Nice job... should be some inspiration to others to make all sorts of interesting looking boxes.
Did you use real wool-felt or is that the "plastic" craft felt?
I scooped the felt on my pipes out of a 30+ year old Marsland speaker box.
More pics
The intention is that once i get a tweeter choosen and mounted & the felt cut to accomodate, i'll stiffen the back of the felt and use it as a grill frame.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2003, 06:34 PM   #9
EC8010's Avatar
I've no idea what sort of felt it was. I thought felt was felt, was felt. How do you tell whether it's felt made from hand-washed organic sheep or synthetic?
I assume the twiddly cuts on your felt are to break up the boundary to the felt and reduce reflections from the otherwise abrupt change of impedance?
Old 31st January 2003, 08:20 PM   #10
frugal-phile(tm)
planet10's Avatar
felt on baffle
Most thin craft-felt is made from a ployester type material and has little effect. If you put a match to it they will have distinctly different reactions (and smells).
Exactly -- you will also note that is has an odd number of points and the number is prime (the latter probably only easthetic). The cut outs are also on a bevel.
dave
felt on baffleHide this!Advertise here!
3-5 mm bitiminous felt ? speakerbug Multi-Way 26 7th March 2008 05:45 PM
WTB: FELT F13 Grey - 1/4" to 3/4" Thick - Like on Duntech/Dunlavy Speakers' Baffle dtm1962 Swap Meet 0 21st October 2006 04:18 AM
Question: What type of Felt does Duntech use for their Front Baffle? F11/F13/F26 or ? dtm1962 Multi-Way 0 16th October 2006 09:58 PM
Looking to Buy some Felt- i.e.Dunlavy or Duntech Front Baffle for Diffract. Control dtm1962 Multi-Way 2 15th October 2006 01:55 PM
Felt metal? Baki Multi-Way 5 2nd February 2005 04:46 AM
