I've been looking for HE drivers to achieve reference levels with good on and off axis response. Eminence Delta 12LF appeals most as a mid at the moment, due to its good xmax, surprisingly smooth response and relatively low cost. Some Q's:
* this driver is designed for bass but is there any reason not to use it as a mid driver? * theMagnum 12 HO driver appears similar, although it has a copper shorting ring and seems the cheapest to have this - any comments on this driver * is there another driver I should consider that might be better? * should I be concerned about the slight peak at the top end? I want a 12" mid for the balance of bang for buck performance, controlled off axis response and not being too big. Here is the response: ![]() http://editweb.iglou.com/eminence/em...rs/del12lf.htm Magnum response: ![]() * What is the highest xo point that is likely suitable for this driver? Could I use a notch filter to tame the peak and cross at 2.5k? Or should I cross as low as possible, say more like 1.7k? Regarding a tweeter, I'm considering 2 options: 1) A planar or ribbon tweeter 2) Vifa DXT25 - the non ring radiator version 90.5 db 1w1m & 140w power handling >>> I'd add a waveguide to achieve +6db eff on the low end This would be a digital active speaker with 8th order slopes crossing to a 12" vented sub at 80 Hz. * Is lobing a problem with speakers such as this, or is it reduced with waveguides and larger drivers with higher directivity?
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#2 |
There must be someone with an opinion on/experience with these drivers?!
#3 |
Hi Paul,
I think you really need the off axis response for the 12" driver, and that of the ribbon/planar tweeter. This question goes back to your beaming Q's you posted. I've attatched a plot of my 10" mids raw response (no eq/crossovers) As you can see it starts to beam around the 1.2KHz mark, and it matched the dispersion of my horn tweets at 1.3KHz...... Also note the breakup at 3K that needs to be avoided too... I crossed 24dB/oct. , considered eq'ing the breakup out aswell, but I can't hear it .. You 12" should start to beam a little lower than this..... Not much help, but..... Rob. |
#4 | ||
It does seem to have a smooth response on-axis, but I think it might start to roll off too early off-axis to be able to mate well with a planar/ribbon tweeter. TBH, I'd look at some Pro 10" drivers for the midrange. They'll extend into the highs a little further, while still being capable enough to provide reference levels. Quote:
#5 |
How do you like the PD107, Rob?. What do you have above/below it?
The new 10" and 12" PD Neodymium drivers look quite nice, maybe you should have a look at them, Paul. Precision Devices |
#6 |
I was looking at the kappa pro wich seems to have good hf extension and just a little breakup.....
http://editweb.iglou.com/eminence/em...kpro/kap12.htm Maybe you could cross higher with that one?
thanks for reading. H.Honda Chico CA Land of the fooled |
#7 |
Hmmm polar response ... seems that info is more difficult to find.
I am now thinking that if I went with the Magnum driver, it probably would have better bass than my subs, hence I could put it in a vented box to get down to say 50 or 60 Hz. My subs are great down low but I suspect the upper bass isn't that good. The xmax is necessary in my case as I either want to go vented and get some bass out of it or cross at 80 Hz with a sealed box, hence I actually do need the xmax or 4.8mm to match my subs at that point. I don't have measurement capability right now, the main problem. I have a diy mic (needs preamp), and speaker workshop but haven't worked out how to use it properly ... Still not sure what I think about this "beaming" thing ... If I understand correctly, at the xo point: * polar response of both drivers should match * both drivers should have low distortion As you go higher up in frequency, dispersion will narrow. Larger drivers will have narrower dispersion. So it seems to me that a large mid is more likely to match dispersion/polar response at xo point than a small hifi mid. So if I put a waveguide on a dome tweeter and put it with a 12" mid, crossing at say 2khz is it likely that I can get the polar response to match? Or does this require a CD and horn?
#8 | |
Beyma LX60 15" below, sealed, 80Hz-300Hz Beyma 380 1" CD on TD250 horn (90x40) 1300Hz up. The PD107 sounds good to my ears, although I was a little disappointed with its measured response compared to the plot on PD's website. Sounded good enough for me to sell my scanspeaks on.. If money had not been an issue I'd have bought the jbl2012 instead though.. OTOH the beymas measured near identical to their plots on Beymas website, and I am totally happy with both the 15's and the cd's. Rob. |
#9 |
Originally posted by paulspencer
-snip- "I am now thinking that if I went with the Magnum driver, it probably would have better bass than my subs, hence I could put it in a vented box to get down to say 50 or 60 Hz. My subs are great down low but I suspect the upper bass isn't that good. " -snip- I'd agree with this point - my setup sound quality wise was much better using my tempests below 40Hz, and 2x10" s-speaks per side from 40 Hz - 300Hz, than with the tempests up to 80Hz. Although using them up to 80 gave more dynamics at the expense of 'tightness' (I know - bad choice of word ) Dunno how crossing a ported bass driver to a sub will affect quality though.-snip- "Still not sure what I think about this "beaming" thing ... If I understand correctly, at the xo point: * polar response of both drivers should match * both drivers should have low distortion As you go higher up in frequency, dispersion will narrow. Larger drivers will have narrower dispersion. So it seems to me that a large mid is more likely to match dispersion/polar response at xo point than a small hifi mid. " -snip- You can have a look at the off axis plots of all the scanspeak drivers on their website. It should give you a general idea of what to expect from different size drivers, and some types of tweeter. http://www.tymphany.com/prodscanspeak.php -snip- "So if I put a waveguide on a dome tweeter and put it with a 12" mid, crossing at say 2khz is it likely that I can get the polar response to match? Or does this require a CD and horn? " -snip- I can't help at all here - I don't know enough about waveguides to be of use. Maybe try and find some plots for waveguide type tweeters to get a general idea. Cheers, Rob |
#10 |
Paul, here's a plot of my horn tweets
I'll post seperate plots for both the mids and tweets raw responses at 0/30/60 degrees in a second. They should show you what I was aiming for at the xo point.. Rob |
| Matching Tweeter to Woofer & Xover | Higo | Multi-Way | 2 | 3rd January 2011 06:03 PM |
| Advice on adding a tweeter to Pioneer B20 8" FR | LowVoltage | Multi-Way | 3 | 6th June 2006 10:37 AM |
| Looking for advice on "sweet" tweeter? | Leonidas | Multi-Way | 7 | 20th February 2006 09:25 AM |
| Matching a new tweeter to existing drivers | Dr.H | Multi-Way | 4 | 22nd March 2005 07:43 PM |
| Page generated in 0.17724 seconds (86.36% PHP - 13.64% MySQL) with 11 queries |
