How do you add a low freq. filter to a 2way crossover? Bypassing worth it?
Old 16th July 2005, 07:48 PM   #1
GuyPanico is offline GuyPanico  United States
GuyPanico's Avatar
Default How do you add a low freq. filter to a 2way crossover? Bypassing worth it?
I'm getting ready to make a simple 2way LW second order crossover for my NSB array. Since these cheap little drivers dont play low, i'm wanting to bandpass them (90hz - 3300hz). How do I add a 6db highpass to my midrange? Do I simply place my 220uF cap inline with the midrange? If so, where?
Also, i'm using cheap electrolytic caps. Which only makes sence since i'm using $.49 midrange drivers. However, would it be advantageous to bypass my 4uF electrolytic cap on the tweeters with a .10uF film and foil poly cap?
Old 17th July 2005, 10:08 AM   #2
Jonathan Bright is offline Jonathan Bright  Australia
I'm having a bit of trouble fitting the idea of a midrange into the diagram you have posted but from what I can work out you just put the cap (220 uF) in series with the mid range. IE amp out put---cap---mid. Just make sure the cap is bipolar which means if the one you have is not then you need to put two caps of about 440uF back to back to get an equivalent value. By the way I think it is genearlly advised to swap one speaker polarity when used in a 12db/octave xover. The answer to the last question is probably yes and as it will cost little should not be controversial.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 18th July 2005, 12:34 AM   #3
GuyPanico's Avatar
Should I place the cap before, or after the inductor in the 2nd order crossover? Or does it not even matter?
Old 18th July 2005, 09:23 AM   #4
for the usual 2nd order network the inductor goes across the speaker terminals and the cap comes before the inductor. That is to say just like the top portion of your illustration but if you use inductors and capacitors it will be a 12 db/octave not 6db. But that is not a bad thing by anymeans.
Old 18th July 2005, 12:28 PM   #5
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Just remember with electro caps, they degrade over time and their value will change, hence they need to be replaced over time. This is why most aim to use poly caps. For long term use you really want polys.
Old 18th July 2005, 04:54 PM   #6
Irwin AR is offline Irwin AR  Malaysia
Send a message via MSN to Irwin AR
Do consider a polypropylene cap instead.
I use 150uF which should give a -6db attenuation at around
130hz... provided your mid is safely at 7 - 8 ohms actual measured.
Solen has this for only ~$40.00 if i'm not wrong.
Yes it is big in size but you could always put it outside your
speaker box as it is not considered part of the XO.
It's purpose are just to protect/allow adequate freq. range
for your mid-tweeter.
EDIT : Oops...you mentioned a $0.49 drivers? i guess my
comments is irrelevant here.
How do you add a low freq. filter to a 2way crossover? Bypassing worth it?Hide this!Advertise here!
Capacitor to filter low freq buzz? steve71 Multi-Way 15 20th January 2009 05:48 PM
Notch filter at x'over freq. of woofer? grantnsw Multi-Way 23 25th August 2006 12:39 PM
HP crossover help (+ resonant freq) Dr. Apathy Parts 3 13th February 2006 11:39 PM
problem with freq filter Magnat biatch Multi-Way 1 27th November 2005 04:40 PM
Bypassing for Solen MKP in crossover? lucpes Multi-Way 25 24th May 2004 10:53 AM
Copyright ©1999-2017 diyAudio
