Got the ich to build !
Looking for suggestions for line arrays for both HT and Music. I`ve never built line arrays, but there always has to be a first time. My intial thoughts are to mount them on the wall on both sides of the screen. I would go down 10 inches below the screen height. The 10 inches below the screen would also be used for the center channel. This gives me a total height of 67'' to work with. I would not to be wider then 12'' and keep the depth to a kept to minimum. I would like a munimum low of 70 HZ Anyone have any suggestions, of it will work, and of drivers? Here's a pic to help |
#2 |
are all the seats at normal seating height?
meaning the seats in this theater aren't stepped higher? |
#3 |
Normal seating height
#4 |
Should have proofed it before I posted
Got the ich to build ! Looking for suggestions for line arrays for both HT and Music. I`ve never built line arrays, but there always has to be a first time. My intial thoughts are to mount them on the wall on both sides of the screen. I would go down 10 inches below the screen height. The 10 inches below the screen would also be used for the center channel. This gives me a total height of 67'' to work with. I would not want them to be wider then 12'' and keep the depth to a minimum. I would like a minimum low of 70 HZ Anyone have any suggestions, will it work, and of drivers? Here's a pic to help |
#5 |
Here's mine. It was my first speaker project. Didn't start small. Just went for it. It'll do 40 hz easy and room enforcement takes over.
Don't need no center channel or a sub with these. 6 - PT2's per side @ 24.80 = 297.60 http://www.partsexpress.com/pe/pshow...number=275-085 10 - 5 1/4 " Aluminum Woofers per side @ $12.55 = $251.00 http://www.partsexpress.com/pe/pshow...number=295-330 |
#6 |
Those look good RG
I`ve been looking at what Zaph has done. See the pic below, I think they are just amasing! I 've been looking at the Silver Flute W14 - 4 ohm, along with the Yag 20 or the Dayton PT2. |
#7 |
Sorry here the pic
#8 |
go for it-build them.i have been wanting to build line arrays with the w14-08 and pt2 for awhile.i allready have 12 of the silver flutes left over from another project..i do know that the silver fluters are great little woofers.
if you build them keep us posted glen |
#9 |
I've been playing around a bit.
Here are a couple of options. On the left side, the array with a 10'' powered sub under. On the right, the array with a 10 '' powered sub beside. Do you have any thought, comments? |
#10 |
OK a Bitmap did not work.
Now the Jpeg is too large. |
| Line Array diy suggestions | ultrakaz | Multi-Way | 4 | 14th January 2011 11:41 AM |
| Line array wiring suggestions | mazeroth | Multi-Way | 3 | 12th April 2005 11:28 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| t-line subs for a DIY line array | tom1356 | Multi-Way | 17 | 28th December 2002 12:15 AM |
| Page generated in 0.11919 seconds (73.50% PHP - 26.50% MySQL) with 11 queries |
