Old 14th July 2005, 05:42 AM   #1
Question Monolith Rebuild
I am in the process of thinking about rebuilding my monoliths which consist of a Fountek JP3 tweeter, a Vifa PL11 (4" midbass), and two Dayton RS270 10" woofers, specifically for smaller footprint.
My thought was to add a second midrange, and make it a 3.5 way design, rolling in the second woofer around BSC, and the midbass section ported to 60hz which seems to make the maximally flat response, and I can't get an F3 of above around 150 with a sealed enclosure, however, would a linkwitz circuit be appropriate?
The new x-over points will be all be LR 4th order at 4000 between the tweeter and mid, and 100hz between the midbass and woofer section.
Thoughts?
(the picture represents a Vifa PL11, Fountek, then Vifa PL11, then there is a port below them on the woofer enclosure, and the two woofers on the side).
Martin Logan Monolith III dsrviola Planars & Exotics 7 17th September 2007 08:16 PM
Mileva & other Monolith shaped speakers planet10 Full Range 45 31st March 2007 04:06 AM
making a CLS into a Monolith? Clarkcr Planars & Exotics 2 16th February 2006 11:18 PM
Monolith First Impressions bjackson Multi-Way 7 17th May 2005 12:37 AM
Martin Logan Monolith III bass fix? georgehifi Multi-Way 11 13th May 2005 02:32 AM
Page generated in 0.07339 seconds (67.89% PHP - 32.11% MySQL) with 11 queries
