Which is the best 8" woofer for a 3 way bass-reflex floorstander, in a 50L box?
Price around 60$! In my country it will be ~37% more! Thank you! |
#2 |
Usher 8137A at PE?
Stephan |
#3 |
Hello
in 50 liters i have proved Peerless HDS205 and it sound very good Middle are Monacor DMH150 (Dome driver) and tweeter is the Vifa PL27 The cut filter for HDS205 is at 750 Hz in a second order LR |
#4 |
Does it have punch?
Can you feel the bass at high volumes, in your chest let's say? |
#5 |
> cut filter for HDS205 in a second order is 750 Hz
Man that sounds high. Is it smooth > 400 Hz? |
#6 |
Hello again and sorry for my english
The cut filter is obligated for de Midle Dome Driver, the fs of Monacor DMH150 is 350 Hz But both Drivers works well at high volume, I only ear the music at high volume during the proves of filter construction With a 4" diameter (10 cm) of the tube reflex it not seems a Boomy BR but is very dinamic and full of energy Best regards |
#7 |
And the box is a very solid costruction
#8 |
I want something that will be cut ~150-300hz!
So any better ones? |
#9 |
Hi-Vi D8.8
#10 |
I want something to go lower maybe F9-10 at 20hz in a vented enclosure of max 50L!
Is it possible? |
| von schweikert unifield 3, an offshoot from "fullranger with helper woofer" | d to the g | Multi-Way | 15 | 24th September 2008 10:34 AM |
| "Box" design and bracing for open baffle woofer array | ryoshu | Multi-Way | 0 | 17th August 2008 06:07 PM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 02:29 AM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Page generated in 0.11496 seconds (69.97% PHP - 30.03% MySQL) with 11 queries |
