I was wondering if these were going to destroy the sound if i used them in place of the L-pad i installed for the tweeters. I Got them for nothing so its not like its a big deal if i dont use them
Persistence is better then intelligence. Unless persistence kills you. |
#2 |
You could try them and listen, either you're satisfied or you're not
When I've changed tweeter resistors in the past I've noticed a break in period that varies from an hour or two up to several days. |
#3 | |
Banned
Not matched, and not easy to set at axactly the same settings on both channels in normal use. A pair of resistors is much better, sorry... |
#4 |
OK ill find a use for them somewhere mabey one day.
#5 |
the advantage to using the L-Pads is that you can set the tweeter level to whatever you want. If you were just going to keep it fixed, I'd suggest using traditional resistors. But, if you want to vary the tweeter level, I'd use the L-Pads. They are popular in pro-audio PA cabinets (need to increase trebble when the crowd shows up....bodies absorb trebble)
| PCM1794 and other tipps/things to build a good DAC | Jakob.z | Digital Line Level | 5 | 30th March 2009 07:53 AM |
| I have things | sauuuuuce | Swap Meet | 0 | 13th October 2006 02:40 AM |
| Things important to be said..helped by Mr. John Mateus to express things. | destroyer X | Solid State | 22 | 31st July 2006 07:21 PM |
| A few things.... | Ziller | Everything Else | 11 | 9th January 2002 04:44 PM |
| Page generated in 0.07134 seconds (81.67% PHP - 18.33% MySQL) with 11 queries |
