Old 16th September 2002, 08:41 AM   #1
Circlotron's Avatar
Default Cube-shaped sub right in the corner with drivers on left, right and top.
I want to make a sealed box sub ~50 litres as per the title, and I have 3 x 10 inch drivers and some wood so it will cost me nothing. Could anyone point me to where someone has done this sort of approach before. I am not after spectacular results, just a bit of added bump and thump.
GP.
Old 16th September 2002, 09:28 AM   #2
audioPT is offline audioPT  Portugal
Hi!
Do this if the speakers are 8 Ohm and the amplifier hangs 2,6 Ohm:
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Left over drivers- very high quality mikelvy Swap Meet 1 2nd January 2006 05:54 AM
ST shaped tube Original Burnedfingers Tubes / Valves 7 13th June 2005 02:02 AM
Shaped PCBs jonclancy Everything Else 12 4th August 2003 07:28 PM
cube shaped sub box hunter Multi-Way 6 12th September 2002 05:11 AM
Copyright ©1999-2013 diyAudio
