Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 16th September 2002, 04:52 AM   #1
bcherry is offline bcherry
bcherry's Avatar
Send a message via Yahoo to bcherry
Default Fertin project - calling all open baffle experts
OK, Dice45 recommended making this an open discussion. I agree; here it is;
Fertin 20cm field coils installed in open baffles 120cm x 60cm x 5cm thick.
Voices are sublime, never heard anything like it. Midbass to treble has cracking dynamics. Very smooth response with none of the peakiness I've experienced with Lxxxxxxr.
But no bass below ~150hz. Any suggestions on open baffle placement/management/size? I'd be happy with 60-70hz with sound this clean.
BTW, speakers haven't been run in more than 2 hrs.
Cheers to all,
Brian
Old 16th September 2002, 05:09 AM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
How did you get them?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th September 2002, 05:14 AM   #3
bcherry's Avatar
TO, my old hometown! Any snow flying yet?
Got them from Fertin. Is that what you wanted to know?
Shipped by Airborne Express in a nice plywood box.
Brian
Old 16th September 2002, 05:17 AM   #4
No snow yet and that what I wanted to know. I am seriously thinking about getting them too. How much were they?
And what exactly do you want to know?
www.audiosector.com
Old 16th September 2002, 05:40 AM   #5
Steve Eddy's Avatar
Default Re: Fertin project - calling all open baffle experts
Usually when I think of things cracking, it's not good. But it seems you're using "cracking" in a positive sense. Am I correct?
I've been eyeballing the Fertins for a while now but there's such scant discussion about them so I want to make sure that what little I'm reading I'm interpreting correctly.
Your baffle seems a bit small to expect much in the way of bass. Also, how much current are you running through the field coil? That directly effects the driver's Q and would also have rammifications as far as bass response goes.
se
Old 16th September 2002, 05:47 AM   #6
The dimension is 17'x18'x10'. Woofer is Focal Audiom 15'. I'm using electronic crossover at 100Hz. In room freq.response is -3dB at 25 Hz. However, I'm also using another 12' woofer on top with slightly smaller enclosure. My point is that the size of a baffle doesn't really have to be big. No frequency correction was required.
www.audiosector.com
Old 16th September 2002, 06:27 AM   #7
Steve Eddy's Avatar
The effective baffle size is larger than your dimensions would suggest seeing as it's a folded baffle. It's effective size is more akin to a flat baffle measuring 37" x 38". Hell, slap one more side on it and it's infinitely large.
se
Old 16th September 2002, 08:08 AM   #8
frugal-phile(tm)
planet10's Avatar
....But no bass below ~150hz. Any suggestions on open baffle placement/management/size? I'd be happy with 60-70hz with sound this clean.
Actually i'm surprised you are getting that low with such a small baffle. If you are getting 150 Hz, doubling the dimensions of the baffle should give you 75 Hz. Keep in mind that the narrow dimensions is the dominant one in determining how low you go.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
Old 16th September 2002, 10:37 AM   #9
bcherry's Avatar
Default Re: Re: Fertin project - calling all open baffle experts
se
'cracking', just like Wallace and Grommit. Yes, good, very good.
My mistake on baffle size: 80cm x 200cm
10V shows about 1.2A. Higher or lower doesn't make a whole lot of difference at this point.
Played another 4 hrs and the sound is getting even better.
Brian
Old 16th September 2002, 10:42 AM   #10
bcherry's Avatar
dave
Sorry, 'tis 80cm x 200cm
My mistake.
Brian
Thread Tools
First open baffle project Moondog55 Multi-Way 18 10th August 2008 05:35 AM
Big open baffle project hugobors Multi-Way 18 18th September 2006 04:17 PM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 10:11 AM
Open baffle drivers configuration: time to ask the experts Peter Daniel Multi-Way 28 31st October 2002 06:54 PM
Page generated in 0.23168802 seconds (85.08% PHP - 14.92% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
