#61 |
Hi Guys,
Open baffles solved a lot of acoustics problems to my system. I presently owned an Altech 604-hpln, A duplex speaker. They sounded great on an open baffles and with my set amp 300b triode. But they are very wall friendly. They have to be closed to the walls and have to toed in to accurately produced a laid back image. I have designed a Dough Sax crossover for my Altech 604, The sounds seems not coming from the speakers... Try It! BUT USE SET TUBE AMPS ! Blue LED's really works. I am doing it on my friends old cd players. Try the green flourescent night bulbs, They also works on any cd players. Happy tweaking Guys, John |
#62 |
Brian,
Did you try it on your CD-94? yet? Players come and go but this one stays with me since 1989. I was curious, did you do any mods on it?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#63 |
frugal-phile(tm)
Brian,
Is the other one tucked in the corner as well? You could build a trapezoidal shape that more closly fits the shape defined by the corner with not much more intrusion and with a less regular baffle shape. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#64 |
Brian,
Is your baffle really 800x2000? Looks like about 800x1200 to me. Unless your camera is an Escher? Baffle fans, This thread having got me intrigued with the idea of trying some baffles (Fertins @$US1500 are out unfortunately) also has me wondering how to place them in a room. Do you set them up like planars, or will they work closer to the front wall? My room has few ways to set them up symmetrically, being wide and open plan. Any tips and suggestions gratefully received. TIA Brett |
#65 | |
Do you have details of the Sax crossover? Brian |
#66 | |
I use it daily. When I first got it from a friend in Vancouver, he said it was soft and veiled so he never used it much. One thing is it was bought from Japan and uses 100V. So I put it on a 100V supply. Also changed the clock, and all the ecaps to Silmics. The Opamps were swapped for 627's. It's not soft and veiled anymore. It's amazing the quality put into this old machines. Just need a little TLC to bloom. Brian |
#67 | |
This is the long wall of my office. There are shelves that you see and then continues open to the windows about 8'. On the other side a similar 'corner is formed by a pr of Tannoy GRF-R. How would you suggest building that trapezoidal shape. Dimensions? Great stuff! Brian |
#68 | |
When I put them out into the room, I find they sound good but midbass and lower dynamics are lost. Voice and sax still jump out dynamically but not the lower registers. So far I found the best position tilted back, toed in and close to the wall. Brian |
#69 |
So that's the Fertin? I've never seen a pic of the front of it.
Is that a whizzer cone? Any close up shots? I would be up for getting into the group buy if, and that's *IF*, I can sell one of the three pairs of speakers I currently have (Lynn Olson Ariels in cherry veneer and a matching TL subwoofer).
-Brad- |
#70 |
Another brave soul.
Alas, we're not going to impress Fertin with our buying power if there are only four of us. Do we want to keep this project among ourselves or expand it to the Joe List and Speaker Asylum as well, just to get more warm bodies? Peter C |
| First open baffle project | Moondog55 | Multi-Way | 18 | 10th August 2008 04:35 AM |
| Big open baffle project | hugobors | Multi-Way | 18 | 18th September 2006 03:17 PM |
| another Open Baffle project | Tomac | Multi-Way | 1 | 14th September 2006 09:11 AM |
| Open baffle drivers configuration: time to ask the experts | Peter Daniel | Multi-Way | 28 | 31st October 2002 05:54 PM |
| Page generated in 0.11916 seconds (80.62% PHP - 19.38% MySQL) with 11 queries |
