Old 20th September 2002, 05:58 PM   #31
planet10's Avatar
Originally posted by bcherry
Got to get one of those frequency test CD's to find out where we are.
This one i have found useful.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th September 2002, 10:41 PM   #32
dice45 is offline dice45  Germany
Originally posted by bbaker6212
Please, please, please, keep the Fertin comments comming. .... ie, what speakers did you used to have, and how do the Fertins better them?
Brad,
this weekend i will make a listening comparison between the reference speakers i use for reality checks and my preliminary Fertin setup. I come back as soon as i have results.
Brian,
i use a similar amp, a #46 PP, even weaker than your #45 PP. I have my Fertins running at 12.9 Volts as the German dealer does. I found no reason to toy around with FC voltage yet, bass is lush and colourful and uncoloured as the midrange and treble. I agree, seamless and coherent is the right term to describe it.
Fertin makes 12" and 15" and even 18" fieldcoils. If i am as satisfied with the Beyma OB subwoofers, i may feel tempted to order 4 of those 18", the drivers are a bit more expensive than the 8".
Greets,
Bernhard
Old 21st September 2002, 01:18 AM   #33
Dice, what are you using for the FC power supply?
-Brad-
Old 21st September 2002, 02:07 AM   #34
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default make a listening comparison between the reference speakers i use for reality check
You should better ask him what he's using for reference reality check speakers.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st September 2002, 06:02 AM   #35
Brett's Avatar
Bernhard,
Which model Beyma 18ërs are you using?
This is an interesting thread, and I'm getting lots of ideas from it. Whist I'm not really interested in buying the Fertins myself, not that I can afford them, I have some Goodmans 201s that will work in an OB arrangement. The Peerless 830500's that Linkwitz uses have similar-ish specs to my LABhorn drivers so might make an intersting experiment later.
Cheers all
Brett
Old 22nd September 2002, 02:58 AM   #36
Brett,
the Beymas are model 18" GT-200.
Er, recently i talked to someone having Goodmans. I described how my Fertins sound in detail, he asked, how much yield Goodmans on ebay? I am sure, he will crowd me soon to isten to me Fertins.
Peter,
when i post my Fertin/Gessner mini comparison, i will describe them a bit, this part of the post has already been prepared. I just did not find the time to do the listening.
Brad,
I am using an LT1085 series regulator with some stunts to get the ripple down before the reg. I mused about a shunt reg but such stuff is a serius challenge for inductive loads and i wanbted some swift result. Moreover, at 12.9V the poleplate is saturated already; hence it does not matter that much if the current thru the field coil is rock-solid constant. At 10V or 7V this may be another matter. To enforce constant current without using a shunt reg, i will try out a huge choke in series with the field coil.
Greets,
Bernhard
Old 22nd September 2002, 01:32 PM   #37
bcherry is offline bcherry  Hong Kong
bcherry's Avatar
Send a message via Yahoo to bcherry
Default how about this as a baffle?
Came up recently in an AA thread:
http://users.starpower.net/je2a3/JELOBplan-1.jpg
Similar to ESL57 dimensions.
Discussed here:
http://users.starpower.net/je2a3/open.htm
where writer suggests that the relationship of the dimensions may be same concept as the golden mean used for speaker positioning in a room.
Brian
Old 23rd September 2002, 08:41 PM   #38
All,
the promised listening comparison has to wait. Today i tried out how the Fertin FC and my trusty old TT cooperate with shellac records.
, read my rave in the analogue board.
Stay tuned
Greets,
Bernhard
Old 24th September 2002, 01:51 AM   #39
Brett's Avatar
Originally posted by dice45
Brett,
Bernhard,
Thanks for the Beyma model.
My 201's would fetch $US250 - 300 at best on eBay, less fees and Paypal, and a pair of Fertins are, what, $US1200+ / pair? Add duties, shipping etc and they are definitely <i>not</i> in my future. For me this idea was to see if anything could rival my horns.
Please let us know what the Goodman's owner thinks of your Fertins in relation to his Goodies.
Cheers
Brett
Old 26th September 2002, 12:18 AM   #40
Bernhard,
I think I've got to do this. I've requested pricing from Fertin's agent. Is this the best way to go? Who is Black Forest and what do they have to offer?
Additionally, my best amps are probably 45 P-Ps, maybe the 45 Loftin-Whites, both at 2 watts. Is there any hope of being able to get good bass response without using a woofer? My experience is that there are such integration problems with offsets, etc. that it's not worth the trouble. I use 15" co-axials now, and I'd really hate to give up the bass response they give. I suppose open baffle is the way to do this, a la Linkwitz?
Peter C
First open baffle project Moondog55 Multi-Way 18 10th August 2008 05:35 AM
Big open baffle project hugobors Multi-Way 18 18th September 2006 04:17 PM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 10:11 AM
Open baffle drivers configuration: time to ask the experts Peter Daniel Multi-Way 28 31st October 2002 06:54 PM
Page generated in 0.12501 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
