Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 9th October 2002, 09:05 PM   #101
Me for a pair.
I've already been talking to Black Forest, so in fairness, I need to tell them what I'm going to do.
Peter C
Old 9th October 2002, 09:55 PM   #102
dice45 is offline dice45
Peter C,
§%$§$%§ !! ok let's see if and how quick i get access to Fertin.
Peter Daniel,
the vacuum tube ghost will haunt you if you buy Fertins!
Greets,
Bernhard
Old 9th October 2002, 10:00 PM   #103
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I was musing tube amp for many years now. Maybe finally I will have a good excuse to build one.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th October 2002, 10:14 PM   #104
Brett is offline Brett
Brett's Avatar
Default Q for Peter C
Peter,
Which Fane driver do you have in your coaxes?
Cheers
Brett
Old 9th October 2002, 10:35 PM   #105
Brett,
I got a pair of 15DX HEs from Adam Hall just before they stopped handing the line in the US. Originally I had Ramsa compression drivers in them, then I stepped up to the big leagues and got some TAD TD2001s.
Peter C
Old 10th October 2002, 11:17 AM   #106
bcherry is offline bcherry
bcherry's Avatar
Send a message via Yahoo to bcherry
Default golden ratio baffle
here's the front
Old 10th October 2002, 11:19 AM   #107
bcherry's Avatar
Default golden ratio baffle - the back
and the other side
Old 10th October 2002, 11:48 AM   #108
bcherry's Avatar
Default now the report
You can see the new baffle is drastically different from the first one I posted. It's built according to the golden ratio used by Japanese audiophiles as previously linked. I knew the driver would be close to the floor, and it was with qualms I had it built, but when I actually saw it come in the door - my heart sank! The bottom is only about 23cm off the floor. I had visions of listening from the orchestra pit.
Here are the measured frequency responses in my room using the Sheffield setup and test disk:
ambient C weighted noise 60db
filtered pink noise 1/3 octave bands
25hz 70db
31.5hz 73db
40hz 75 db
50 hz 78db
63hz 81 db
80hz 85db
100hz 87db
125hz 88db
160hz 88db
200hz 87db
250hz 85db
315hz 85db
400hz 85db
500hz 82db
630hz 82db
800hz 82
1khz 81db
1K25hz 82db
1K6hz 81db
2Khz 81db
2K5hz 80db
3K15hz 79db
4Khz 79db
5Khz 81db
6K3hz 84db
8Khz 84db
10Khz 82db
12K5hz 78db
16Khz 73db
20Khz 69db
So the sound is now coming in at 40hz and saying goodbye at 16Khz (if my SPL meter is to be believed). Also there is a nice hump from 80hz to 250hz which now gives somes weight down there. Measured in position as shown in the picture.
Image height doesn't seem to have suffered. I still get sounds coming from my musical reverie painting. Low bass is pretty good. Overall tonality is much more balanced.
But why does this work? Is there really something going on with this 'golden ratio' thing? The configuration is counter to all the advice given about keeping the driver 70cm off the floor.
I'll play with positioning and interested to receive any suggestions about it.
Another issue. The former attached to the driver had started to scrape the cylinder. I don't know the proper procedure but here's what happened: The nuts attaching the suspension came loose so the driver went off centre. I loosened all three nuts so the suspension was loose, then slid a thickness of paper around the diffuser into the gap (from the front). This kept the former equidistant from the cylinder walls; tightened the 3 nuts up and it worked! No more rubbing.
OK, that's the latest installment. I think we're closer to home now.
The BEhringer could do the rest.
Brian
Old 10th October 2002, 04:04 PM   #109
Wow, 10db down from 10K to 16K. I'm having a hard time understanding how this thing cannot sound dull, rolled off, and lacking in detail. Do cymbals, high-hats, etc., sound real with these?
-Brad-
Old 10th October 2002, 04:19 PM   #110
What mike are you using? Most of the mikes are OK at mid frquencies, but when it comes to both ends of spectrum they might be deceiving. You ears are the best test. If the highs seem to sound OK the mike lies.
www.audiosector.com
Thread Tools
First open baffle project Moondog55 Multi-Way 18 10th August 2008 05:35 AM
Big open baffle project hugobors Multi-Way 18 18th September 2006 04:17 PM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 10:11 AM
Open baffle drivers configuration: time to ask the experts Peter Daniel Multi-Way 28 31st October 2002 06:54 PM
Page generated in 0.22601700 seconds (81.53% PHP - 18.47% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
