Midly off subject but, where does one find cheap wire for winding your own coils. I got really excited about winding inductors a little while ago, but from everything I've found you just can't beat the price of the Erse inductors from Parts Express when it comes to large inductor values.
Madmike if you're looking for a more frugal wire that still sounds good try cat5e plenum which is used in hooking up computer networks. Cheap, and decent. Solid copper wire with teflon insulation.
Joe
Joe
Josephjcole said:try cat5e plenum which is used in hooking up computer networks. Cheap, and decent. Solid copper wire with teflon insulation.
The cryo wire Take 5 sells is cat 5....
dave
Madmike2 said:Big diff between the silver and the cryo copper Dave ?
Don't know....
dave
What would be the next step in chain ? I am guessing a pre-amp with what i have is pointless right now(Pioneer reciever/amp SX-737). A high quality DAC ? I am itching to see if it gets even better at the source then this Delta 66 . Before i continue on to better amplification i want to top this out.
Madmike2 said:What would be the next step in chain ? .... (Pioneer reciever/amp SX-737)
Get a better amp... The Pioneer is the kind of thing i put into whole systems for <$200 (and won't bother with for my own lab or workshop systems). Go talk to Peter Daniel....
dave
Madmike2 said:Must see what he has
My guess would be the most affordable hi-quality SS amps in TO.
dave
- Question for Planet-10 or another Guru
