Old 8th July 2005, 07:54 PM   #1
Default Explain this crossover
Hello all, could someone explain this highpass XO for me. I know its a 3rd order, but what does R1 do. Dont you normally need 2 resisitors for a pad? And why are C1 and C2 the same value? The crossover is from an Adire kit, that I want to use a different tweeter on. The XO freq is 3500hz.
Old 8th July 2005, 08:26 PM   #2
SY's Avatar
R1 drops the driver level. You need two resistors for a pad only if you don't want the series resistor to change the load impedance. For a parallel crossover, it's a non-issue.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th July 2005, 08:34 PM   #3
Ok, so I could replace R1 with a pot and be ok then? And is it unusual that both caps have the same value?
Old 8th July 2005, 08:41 PM   #4
SY's Avatar
The ratio of the caps' value is an indication of the sharpness of the crossover rolloff.
If you're thinking about using this crossover for a different driver, you're heading in a bad direction, potentiometer or no potentiometer. What you need to do is, using the actual impedance and SPL data of the original tweeter, determine what the electrical and acoustic response near the crossover region look like. Then your task is to duplicate it with a different tweeter. Doing it right will not be trivial, but with real data and a good command of a speaker CAD program, it is possible.
Old 8th July 2005, 09:08 PM   #5
steenoe is offline steenoe  Denmark
steenoe's Avatar
SY, how come you have the danish actor, Dirch Passer, as your avatar??
Steen
Old 8th July 2005, 09:11 PM   #6
SY's Avatar
Ding ding ding! You get the award! He attracted my attention when I was a kid with his role in that classic piece of Danish cinema "Reptilicus."
Now I have to find a new one.
Old 8th July 2005, 09:18 PM   #7
steenoe's Avatar
What is the reward then? A years free subscription to "my" forum?? Well, I did donate the 20 bucks, allready Any Dane would guess that one
Steen
Well, it is much prettier than the ugly puppet you had before Made me sick
Old 8th July 2005, 09:47 PM   #8
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Unless R1 is incorporated in a corrected Rtot for the load, it will also modify the slope of this HP section.
Without knowing the details of rest of the circuit, it is next to impossible to know the exact purpose of R1.
If the sole purpose was to reduce the level of the tweeter, there should be an R2 to ground, to complete an L-pad.
Old 8th July 2005, 09:51 PM   #9
SY's Avatar
You only need an R2 if you're trying to keep the impedance the same. Why bother to do that in a parallel crossover? Remember, R1 is not an aded component for a modification, it is the resistor that is part of the original design.
Old 8th July 2005, 09:58 PM   #10
AuroraB's Avatar
that's exactly what i mean....
The filter is undoubtably 3rd order, but R1 will also modify the stop band curve, or the "knee" if you like, so unless you know the details of the total contraption, or more exactly the designers purpose, there is several options to the function of R1
Can some one explain me this amp? Tarzan Solid State 22 3rd January 2008 07:06 AM
Please explain this crossover...??? gcm908 Multi-Way 44 1st November 2006 06:03 PM
Another please explain this crossover ... TurboFC3S Multi-Way 18 3rd October 2006 03:08 AM
please explain this crossover... gcm908 Multi-Way 7 17th February 2005 07:17 AM
Page generated in 0.09928 seconds (75.28% PHP - 24.72% MySQL) with 11 queries
