Another Line Array Speaker Thread
Old 7th July 2005, 05:53 PM   #1
dhenryp is offline dhenryp  United States
Default Another Line Array Speaker Thread
I’ve finally “finished” my line arrays using my DIY ribbons (see: http://www.diyaudio.com/forums/showt...threadid=50162). I say “finished” because the crossover is currently a junk box1k first order. I’ll probably build a more formal passive second order as a temporary measure until I complete an active crossover. The ribbon is a 47” seven segment ˝” true ribbon. The main cabinet is sealed and has 14 – 4.5” PE Vifa buyout mid/woof (P/N 299-432) in a 4-3-3-4 taper. The main tower is East Indian Rosewood with Satin water based Poly finish while the tweeter box and base are black lacquer. How does it sound? I just finished it last night and have limited time on it but like it a lot. The Vifa’s have surprisingly good bass and the tweeter sounds clean and extended. It has a crude crossover and I’ve made no measurements yet so you can assume my listening impressions are highly with colored DIY builder pride. It’s my first line array and first ribbon (in fact it’s my first full range DIY speaker).
Old 7th July 2005, 06:22 PM   #2
gl is offline gl  United States
Beautiful job dhenryp! Thank you for posting the pic.
GL
Old 7th July 2005, 06:27 PM   #3
Madmike2 is offline Madmike2  Canada
Madmike2's Avatar
That looks pretty sweet dude
Persistence is better then intelligence. Unless persistence kills you.
Old 7th July 2005, 09:12 PM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Those look absolutely beautiful, but it looks like you ran out of stain on the bottom corner
Keep us updated how they sound with the new XO and some break-in time.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 7th July 2005, 09:27 PM   #5
Audiophilenoob is offline Audiophilenoob  United States
very nice... now how does it sound?
does the diy ribbon sound nice?
Old 7th July 2005, 11:32 PM   #6
Paul W is offline Paul W  United States
Paul W's Avatar
They look great Denis! The wood is spectacular, but that beautiful black lacquer probably took just as much work!
Paul
Old 7th July 2005, 11:59 PM   #7
mwmkravchenko is online now mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Thumbs up Looks Goood
What are you doing for an encore!
MArk
Mark
www.kravchenko-audio.com
Old 8th July 2005, 12:20 AM   #8
Cal - Thanks for pointing out the corner I missed. I'll get right on that
Paul - you are right abought the lacquer. It takes a long time - and just to site in a dark HT
Mark - my next project is to paint the house. I'm thinking of doing it in black lacquer
Seriously, after the tempoprary second order, I'm building an active fourth order plus three chip amps to drive each speaker (one for the ribbon and two for the mid/woofs). This probably won't get done before the winter.
Old 22nd November 2005, 04:32 AM   #9
Mallickarjuna is offline Mallickarjuna  India
Mallickarjuna's Avatar
Send a message via MSN to Mallickarjuna Send a message via Yahoo to Mallickarjuna
Denis,
Excellent! Workmanship.
Generally the line array speakers have an array of individual tweeters, they form a mounting gap in-between, and in your case it will almost have a full length. We will be keen when you are ready to post the test results.
Mallick
Old 22nd November 2005, 05:23 PM   #10
Tyimo is offline Tyimo  Hungary
Default Line Array Speaker Theorys
Hi!
Very nice speakers! Congratulations!
Could somebody tell me what are the advantages, (disadvantages) of the Line Array Speakers? Or, where can I read about it?
Greets:
Tyimo
Another Line Array Speaker ThreadHide this!Advertise here!
Speaker choice for line array MPM Multi-Way 9 21st December 2007 07:40 PM
yet ANOTHER PE 269-570 line array thread MEXXX Multi-Way 17 7th October 2004 06:26 AM
line array speaker selection.... onis_uk Multi-Way 8 4th August 2004 08:05 AM
Another line array thread! Hybrid fourdoor Multi-Way 6 2nd August 2004 12:52 PM
