Old 6th July 2005, 01:33 PM   #11
kan3 is offline kan3  United States
The 1" exit B&C de200/250/25/500 are all good sounding drivers at great prices. Definitely the top of my list, especially the de25 and de250.
I don't have any experience with the 2" drivers but none of them really striked my interest with their crappy FR plots. Can I ask why you're going with a 2" instead of a 1" exit? Is the lower frequency response the only reason?
The de500 is a beast and will do +/- 3db from 900hz-17khz at >105db@1w and is extremely tiny and light weight for its performance.
Old 6th July 2005, 02:47 PM   #12
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Hello all and thanks for your replies, they are helping a lot. kan3, we are going with 2" because of lower response (although the cabs are crossed at 1.6k) and power handling, and the horn in the box is a already a 2" Thanks!
Old 6th July 2005, 06:01 PM   #13
The Selenium D3500Ti is a very good unit, but it is pricey (as most all neo units are). More cost effiective are the Selenium D4400Ti (4' dia) or the D3300Ti (3" dia). Both have very good extension, but are again heavy. A good buy are the older D405Ti or D408Ti. These are a bargain if you are on a budget. Again, heavy.
If you want very smooth neutral midrange, the D405 with a phenolic diaphragm is great, although you will need to use a tweeter with it, since it rolls off above 5k or so. This is my personal favorite in a 2" compression driver (from a hi-fi perspective). I dont mind using a seperate tweeter, and would do so even with the wider range units using titanium diaphragms, due to beaming with any decent midrange horn. If you havent used Selenium products, do yourself a favor. The favorible exchange rate makes them a real bargain compared to JBL, or the European offerings of similar quality.
2" affordable compression drivers usa_satriani Multi-Way 107 16th November 2008 08:21 AM
looking for good compression drivers mahalta Forum Problems 0 19th May 2008 12:58 PM
Keele, D. (2004) "Maximum efficiency of compression drivers" svenr Multi-Way 3 28th October 2007 02:03 PM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Page generated in 0.07623 seconds (72.86% PHP - 27.14% MySQL) with 10 queries
