So I've read through most of my new book: "Woodworking with the Router" but have yet to understand how everyone is routing the recess around the speaker cutout.
So should I: 1.Use a circle jig and plunge into the recess first, then cut out the mounting hole 2.Cut out the hole, then use a template to rabbet/mortise the recess from above 3. Cut out the hole, then ride the edge of the hole to rabbet the recess Thanks! Paul |
#2 |
I also am interested to know this, as I will be building some bookshelf cabinets in a few weeks, and am told that not countersinking the tweeter is a bad idea.
The power of Science compels you! |
#3 |
Don't do any of that, throw the router back in the box and get a refund.
Then carefully use a hammer and chisel to make your holes, its what I do and the fit is perfect if you look at it from the right angle. Hope this helps ![]() PS. Its number 1 in your list |
#4 |
Hammer and a chisel you say?
#5 | |
Paul |
#6 |
diyAudio Moderator Emeritus
Recess first. Some pics:
http://www.vikash.info/audio/xls10/construction.asp
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#7 |
Thanks for your help, guys.
#8 |
You can use #3 as well, simply cut the hole and then use a piloted rabbet bit to follow the outline of the hole. This method makes controlling the depth of the recess very easy.
Pete |
#9 |
Another method without using the jig.
I've used this myself.Works great on irregular mounting flange http://www.exquisiteaudio.ca/baffle.html |
#10 | ||
Yeah, #3 and the method in the link are the same. I was considering this if I use the Peerless HDS woofers. Thanks guys!
| PCB Routing | Mark245 | Parts | 15 | 27th May 2009 07:54 PM |
| Why new xover sounds recess and lacks dynamic | andy2 | Multi-Way | 9 | 14th August 2006 12:56 PM |
| MDF cnc routing | dhole | Multi-Way | 1 | 21st January 2006 04:38 PM |
| To recess or not to recess | AntM | Multi-Way | 4 | 23rd June 2005 04:58 PM |
| What to do if tweeter recess is too large | Goldenboy | Multi-Way | 12 | 25th February 2005 09:26 PM |
| Page generated in 0.11114 seconds (79.44% PHP - 20.56% MySQL) with 11 queries |
