Old 3rd July 2005, 01:04 PM   #1
Trout is offline Trout  United States
Trout's Avatar
Default 1948 speaker qusetion.
I just bought a bunch of old tube consoles. Generally speaking, I have loads of fun rebuilding them, Most as practice guitar amps.
I ran into a few over the weekend bought the lot for 20 bucks(3 units)
Anyway, I got this old late 40's Stromberg Carlson (1948 based on tube date codes) With A Field coil? 12 inch Speaker
Stromberg Carlson
I havent any data that goes back that far on this type of stuf. These things still useful other than restoration work?
Did stromberg Carlson actually make speakers? or can somebody ID this speaker>?
Gene
Old 4th July 2005, 03:24 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Yes, they did. Field coil drivers are highly prized in some circles, though I'm not sure if theirs are. You may have better luck $$ wise selling the the electronics with it.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th July 2005, 12:10 AM   #3
Trout's Avatar
Originally posted by GM
Greets!
GM
The electronics unit itself was pretty rough. It had a Nice 1948 Pair of Cunningham 6V6gts that amazingly still read at just over 100% on my tester. The Wax paper caps were litterly popping their ends out! Humming but still passing signal.
As it turns out, The Stromberg Carlson unit I pulled this from was actually sort of a amplified Victrola! It only played 78rpm records!
The Push Button tuner was really messed, Bent internals, Turntable was messed up. Other than the Tubes and Speaker, It was pretty sad shape.
gene
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
Restoring 1948 Gibson GA-30 guitar amp(tube) Tristanc1 Tubes / Valves 5 21st February 2008 05:38 PM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Some Speaker Completed Speaker Projects dc270 Multi-Way 1 19th February 2006 01:33 AM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
Page generated in 0.08098 seconds (71.44% PHP - 28.56% MySQL) with 10 queries
