Old 28th June 2005, 06:14 PM   #1
lovitz is offline lovitz  Canada
Default PMC Drivers
Does anyone know specifically what drivers are used in PMC loudspeakers?
I'm specifically looking at the models:
TB2S
http://www.pmcloudspeaker.com/tb2s.html
IB1S
http://www.pmcloudspeaker.com/ib1s.html
Thanks.
Old 28th June 2005, 06:36 PM   #2
ShinOBIWAN's Avatar
PMC use Vifa, Volt, ATC and some in-house drivers in their designs.
Old 29th June 2005, 09:18 AM   #3
Puggie is offline Puggie  United Kingdom
the TB2 uses Vifas, the IB1 looks like vifa mid and tweet and I believe the LF unit is an in house job, it looks like the old Elemental Designs flat cone subs but no way would they play high enough to be a midbass.
Old 29th June 2005, 10:58 PM   #4
IB1 uses vifa tweeters? I think it looks for like a Morel MDT 30-33
Old 30th June 2005, 08:47 AM   #5
Hmm, could be actually, I know the TB2 uses Vifa, I thought they used the same tweet but I could be wrong.
Old 30th June 2005, 10:56 AM   #6
Apon closer inspection it indeed is a Vifa, D27 or something like that
Thanks for the replies!
Old 30th June 2005, 11:05 AM   #7
paulspencer's Avatar
It's hard to tell just by looking, since they often use modified versions that look the same. SVS use a TC sounds driver that looks identical to the AE speakers AV12, but its actually a modified version of a TC sounds driver. I also thought that a Genelec subwoofer used the XLS, however, when I saw it, I was clearly wrong. Similar but different.
Why do you want to know?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 22nd October 2005, 12:42 PM   #8
Tomg is offline Tomg  United Kingdom
thread from the dead
Incase you didn't know by now, the tweeters used in almost all of PMCs range is the Vifa D27TG-35-06 and in the TB2, the midbass unit is a Vifa M17WG-09
Old 22nd October 2005, 12:45 PM   #9
Old 22nd October 2005, 04:20 PM   #10
wow
thanks for the reply Tomg!
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Page generated in 0.10384 seconds (78.19% PHP - 21.81% MySQL) with 11 queries
