Does someone know this speaker? - Page 3 - diyAudio
Old 29th June 2005, 12:04 PM   #21
5th element's Avatar
AP170Z2 = made up audax number but the Z2 stands for aerogel cone, second unit in that series. In other words they have a Z0 but was replaced with the Z2. The two doesnt stand for duel voicecoil.
Remembering what I have read about aerogel is that it can be finished on th front surface to resemble anything it likes. So audax standard gel units all look the same on the front, a kind of grey/red/brown, but anyone elses may look completely different.
I agree with docjoe that it is an aero cone, I have several little aero drivers lying around the reverse cone looks exactly like the pictures posted here.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 29th June 2005, 12:34 PM   #22
docjoe is offline docjoe  Europe
docjoe's Avatar
Hi
While working with "Audio-Referece" speakers company I had a lot of speakers to test and we had special versions made to specifications for us by Audax.
the aerogel outer face could be grey, glossy our mate, black, usually glossy, but the back face was always grey, exactly like on the 3rd picture on the first post.
thats why i was so affirmative.
docjoe.
Old 29th June 2005, 02:21 PM   #23
e-side is offline e-side  Netherlands
I haven't any experience with aerogel, so i can take more pictures when needed.
Originally posted by C37
BTW, Usually OEM units are tailored for a certain internal volume the manufacturer wants to use, etc etc... Vas, Qts,... might differ significantely from the generic audax unit.
But even if this driver is an aerogel, the tsp can still be different can they?
Old 29th June 2005, 03:31 PM   #24
docjoe's Avatar
yes, different
but knowing Vision, they were familiar with 2 drivers 3 ways speakers, so yours would fit in a 25/35 litre enclosure, bass reflex loaded.
you can measure the minimum TS parameters with a simple VOM
a sinewave generator and a couple of resistors.
I dont know where you live but you could buy David Weems book
"how to design,build, and test ..."
its quite old but contains usefull tips for the beginner who cannot use sofisticated computer test gear.
http://www.diyaudio.com/forums/showthread/t-10617.html
docjoe.
Old 29th June 2005, 07:52 PM   #25
i'll try to measure the tsp first so i'm sure how to build the enclosure. I already tried something, but the sound was very disappointing. I only need qts, qms, qes, vas and fs... can't be very difficult.
Old 29th June 2005, 10:25 PM   #26
docjoe's Avatar
ok, but david weems explains how to measure those parametres with simple tools
docjoe.
Old 30th June 2005, 04:28 PM   #27
Question measuring tsp
I got the material to measure the tsp, and now i have te measure the Fs. I don't have experience with this, so which type of voltage do i have to use on my multimeter, DCV or ACV ? i think it has to be ACV, but then it's very difficult to determine when the voltage becomes at a minimum level because the most low frequencies are close to 0,1
Probably it's a stupid problem, but i can't solve it
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 06:34 AM
Mounting speaker. Speaker gasket? Cal Weldon Multi-Way 0 11th April 2007 11:36 PM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 28th May 2006 12:14 AM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 11:12 PM
Pi Speaker Reviews/or Similar Speaker G4ME Multi-Way 4 17th June 2003 01:26 AM
Copyright 1999-2017 diyAudio
