Old 24th June 2005, 02:21 AM   #1
Madmike2's Avatar
Default x-overs
HI again. Ok i need help with the x-overs. i dont have the software or the ability (skills) to design them.
The speakers are a Morel 166 which you can see here www.solen.ca [click speakers and then Morel]
with the Hi-Vi RT8II tweeter which you can see here http://swanspeaker.com/product/htm/view.asp?id=18
You will notice that the tweeter is far more efficient then the woofer thus another problem that i doubt i could solve without help.
I want to follow some advice i have been given on this forum and x-over out of the vocal/presence range so 3k + and then whatever tweeter attentuation is recommended by experienced DIY'ers.
I can follow schematics just fine and am more then willing to listen to sage advice if its warranted.
Thank you in advance for your assistance.
Persistence is better then intelligence. Unless persistence kills you.
Old 25th June 2005, 12:23 AM   #2
i tried modeling it in crossover pro for you but, not solan or swan have enough specs on the hi-vi to model it.i had the same problem with the lcy110-couldn't get the full specs.you should ask chris at solan to model it for you.he as never charged me for the crossover design!it may not be exact,but a good starting point
glen
Old 25th June 2005, 05:00 AM   #3
Madmike2's Avatar
I spent a day looking everywhere for someone who has used this speaker. I was about to give up when i found a japanese version of Yahoo where a gent had it in his profile. Roughly translated by my friend it looks like a 6db first order crossover 2500 hz and 18 db on the woofer. Strangely there was also other values in the schematic that apparently were resistors. I am still figuring out what they are for but i am assuming attenuation. I am ordering a x-over program so i can stop asking questions here about this thing. I just want to finish it and see what happens , good or bad. If its bad i start again and do things differently . If its good ill start tweaking. At least my subs cant fail.
Speakers were something that was in normal letters as B+C plus the Hi-Vi Tweeter.
Old 25th June 2005, 11:42 PM   #4
Madmike2's Avatar
They are assembled now. Drinking and surfing e-bay for some small tube amps mabey i can get lucky and find a pair of stereo 20 watters
Branching x-overs Temporal Multi-Way 4 4th November 2007 10:52 PM
MTM X-overs. Tristanc1 Multi-Way 2 3rd March 2006 03:15 PM
Capacitors for Cross-Overs 2x6spds Parts 1 14th November 2005 01:13 PM
Page generated in 0.08604 seconds (74.44% PHP - 25.56% MySQL) with 11 queries
