I've owned lots of commercial speakers and didn't want to build a small speaker as my first project so I decided to go all out. This speaker uses (10) of the Vifa JBL 4.5" 6ohm buyouts from PE as well as a single Fountek JP-2.0 ribbon tweeter. Using a Behringer DCX2496 with the crossover set to 2500hz. The sound is PHENOMENAL!
I still need to make bases for them and will paint them with the same black truckliner spray I used for the baffles. Also, I used a flash with this picture so the birch sides resemble the darker, bottom portion of the speaker. Tell me what you think: |
#2 |
Nice, check mine out:
My 1st Speakers |
#3 |
Very nice job! I am interested to hear your opinion of the bass performance of the 4.5" Vifa buyouts.
-How low do they go? -Are you running them sealed? How big a box? -Have you got any BSC cranked into the crossover? -What kind of base are you building and what material are you using? I'm close to completing a line array of my own with the 12 ohm version of the Vifa's and a DIY ribbon. |
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| Mounting speaker. Speaker gasket? | Cal Weldon | Multi-Way | 0 | 11th April 2007 10:36 PM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Pi Speaker Reviews/or Similar Speaker | G4ME | Multi-Way | 4 | 17th June 2003 12:26 AM |
| Page generated in 0.09644 seconds (66.72% PHP - 33.28% MySQL) with 11 queries |
