I have a quick question in regards to the distance between speakers. I have read that the vertical distance is a relation to the wavelength of the highest freq., I assume this is the crossover freq.?? Is this distance from center to center of the speaker?
In a TMW 3-Way, would the spacing between the woofer and the midrange be the lower crossover freq. and the spacing between the midrange and the tweeter be the upper crossover freq.?
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#2 |
AFAIK: the distance between the centers of two units should be at least half of the wavelength of the cross-over frequency.
But it also depends on what order filter you use. A higher order gives you a greater distance. Grtz, Joris |
#3 |
Thanks, that answers my question.
#4 |
OK...been doing some reading.....I have seen 1/2 wavelength, 2/3 and 1 wavelength, which is it? Does each correspond to a certain type of crossover? If so, is there a website that summarizes that?
#5 |
Basically, closer is better. Some people say 1/3wl actually. It's most important when using first order crossovers, to reduce comb filtering. Higher order types can get away with wider driver spacing. 'Course, they're less likely to need it... I prefer 3 ways with wideband drivers and first order crossovers myself.
GB |
| wmtmw driver spacing | kifeinthesink | Multi-Way | 6 | 6th April 2010 11:08 PM |
| Driver Baffle Spacing | vdi_nenna | Multi-Way | 3 | 22nd April 2008 11:02 PM |
| Driver spacing ... ? | REALFLEO | Multi-Way | 2 | 15th November 2006 07:07 PM |
| driver spacing | memphissound | Multi-Way | 7 | 21st August 2006 03:29 PM |
| is driver spacing important ? | busterno1 | Multi-Way | 12 | 9th February 2004 06:28 AM |
| Page generated in 0.07963 seconds (70.70% PHP - 29.30% MySQL) with 10 queries |
