#11 |
We don't just use IP adresses to detect Sock Puppets...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 |
I tend to side with DIYaudio moderators on this.
Bill never gave out any accurate FR curves (by accurate I mean every testing condition, how could you achieve what is advertised... etc), couldn't back up anything IMHO, and timed after every Bill post, there's a Jim York post to back him up with big fanboyism. tiroth measurements proved this to my eyes, Bill plans are way overhyped. If he was really banned unfairly, he would have at least asked why, especially since he was probably making good business with DIYaudio. I think he doesn't care because he knows he was wrong on this. At least he wasn't charging alot for his plans so it's not "that" unfair.
DIYaudio for President ! |
#13 |
Well.
The rubbishy Maplin meter I have is not going to make any conclusive results, so I'll put that aside for a moment (unless someone knows of a way to make a flat response mic I can connect to my pc, and a piece of software to do all the hard work?). The autotuba is great, but like tiroth it's awkward to get the desired low-end response without messing around with equalisation. I did some quite unscientific tests (this whole thing was an advanced higher physics project after all...) and basically concluded the following: 1. The Autotuba is very sensitive to room placement. It likes corners and facing down to the floor, with (oddly enough) one edge of the mouth touching the floor, and the other about an inch off it. ie, leaning over precariously 2. The Autotuba is best for in-car use. It also suits smaller cars with shorter 'resonant chambers'... an equaliser would probably do a world of good compared to my rubbishy head unit's bass controls, but still. 2.5 The Autotuba works well at low volumes and excursions. I have built two of them (the first, rather shaky attempt was mine, the second rock-solid one was for a friend... 127dB at 40Hz, using ~100w input power, my one just rattled horribly) and found that they sound the best at lower volumes - I've found they have a tendency to 'boom' and in some cases make loud popping noises. All of which were quite disconcerting for the driver I paid $70 shipping to get! (well, two drivers technically but...) 3. The Autotuba doesn't work very well outside. It needs what I presume to be the horn effect of a car (with the front doors open... Mmm... I found a large node about 50m away, sitting around about 15Hz 4. The construction plans are quite vague... hence I ended up using about 300 screws during its construction. I agree that Bill really does have to answer for the inconsistent test results he provides.. even though I admit, different cabinets perform in different ways depending on the conditions, but a typical concrete-floored room of 4m by 4m, with plasterboard walls and carpet would make a nice benchmark. Some more hints as to get the best out of the designs would be nice too Back on topic, anyhow - cheap cartridge microphone with a flat response, and software to do the hard work for me (graphs + sweeps)? Thanks Karanael |
#14 |
A basic SPL meter like the one sold by Radio Shack and TrueRTA software would do the trick hehe!
| Horn responses | AuroraB | Full Range | 24 | 12th August 2008 08:17 PM |
| Suggestions for AutoTuba Amplifier | BassAwdyO | Car Audio | 6 | 31st July 2005 04:34 PM |
| Autotuba measurements, plus shiva | tiroth | Subwoofers | 59 | 26th July 2005 08:38 PM |
| Page generated in 0.16236 seconds (48.76% PHP - 51.24% MySQL) with 10 queries |
