TB4D (plans of a 4'' Tangband 2way)
Old 23rd June 2005, 12:12 AM   #11
joensd is offline joensd  Germany
Did you listen to both or just the floorstander?
Just listened to the TL and I reckon it has better bass capabilities.
Still very small, skinny and high-waf-design.
Please post the data to my email for evaluation.
Turn your mails on or send me one.
jens
Old 23rd June 2005, 02:16 AM   #12
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
ok you got mail
Old 23rd June 2005, 11:24 PM   #13
Salas's Avatar
seems like you like to design yourself but please have a look at this:
Thanks for the plans. After studying the Te-el, I must say I would not be tempted comparing to the TB4D. It achieves 50 Hz needing to be a 110cm floorstander with a back tail when the TB4D does 48 hz being 40cm tall. Then the Te-el is 88dB when the TB4D is 90dB. Its crossover uses 6 elements when TB4D requires only 3 (2.2//2.2uf counts as one).
It must be good sounding but I suspect a less controled box coloration and possibly a pipe resonance. All cavities are bad things and I prefer a small reflex cavity to a long pipe one. I would use a folded horn if to make a floorstander with 2 W657.
Old 18th February 2013, 04:32 PM   #14
Salas's Avatar
The old girl got a proper dress...at last.
Old 19th February 2013, 02:50 AM   #15
Jsixis is offline Jsixis  United States
Nice Job
Old 19th February 2013, 09:39 AM   #16
flaevor is offline flaevor  United States
flaevor's Avatar
The Grünanlage just underwent an update. Salas low pass filter is pretty close to the blue planet acoustic crossover but the tweeter really should have a 12 db high pass.
Salas is absolutely right about the bass extension. The TL and BR go equally low but obviously they sound a little different.
The TL was recently profiled in Klang + Ton. The speaker is totally worth the money.
Old 19th February 2013, 12:03 PM   #17
Salas's Avatar
The tall German version is quoted something like 87dB sens per W? This one is 90dB with no attenuation on the TW combining the 6dB electrical and the acoustic roll-off. Its possible they don't have that much difference in tweeter THD when playing same moderate SPL for used Wattage. Although I found the 1st order more coherent for transition and more expansive for sound stage when I designed it ~6yrs ago its likely the 12dB could be more THD controlling when pushed far. It plays in a small living room and never coughed in there though.
TB4D (plans of a 4'' Tangband 2way)Hide this!Advertise here!
Help on 2way DIY Enclosure pcyl Planars & Exotics 2 10th February 2009 01:31 PM
SEAS 2way tpsorin Multi-Way 29 28th July 2007 09:50 AM
css 125's & Adire 6.8's in a 2way sys binarywhisper Multi-Way 39 22nd February 2006 08:05 PM
Seas 2Way. Baronty Multi-Way 10 20th October 2004 08:24 AM
