damping of series vs parallel
Old 22nd June 2005, 06:42 AM   #11
jomor is offline jomor  Greece
jomor's Avatar
Higher inductance prevents the amp to control easily the cone. When we connect an extra inductance (the second driver) in series with the first one, doenst the total inductance shown to the amp increase? Btw check out this link
http://www.adireaudio.com/Files/Tech...ooferSpeed.pdf
Old 22nd June 2005, 08:59 AM   #12
lopan is offline lopan  United States
Default nice link
cool link some good information there although the fourth paragraph is wrong; the force generated on the VC has nothing to do with the magnetic field generated by the current in the VC but instead by the simple fact that moving a current through a B field generates a force iL cross B or maybe vice versa.
It is interesting when dealing drivers needing high transient speeds ie. tweeters. Any high trasient signal is created, if we look at it in the frequency domain, by a large amount of high frequency informationwhich is filtered off by the cross overs.
Further significance is that for mid base drivers and mids there is an inductor in the loop for its Low Pass characteristics. This inductor usually swamps out the drivers inductance.
All said and done still some intersesting information on that site
Take care
damping of series vs parallelHide this!Advertise here!
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 19th February 2014 11:16 PM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 04:42 PM
Series vs parallel? legendaryfrog Full Range 5 14th December 2006 02:50 PM
series vs parallel SPL? 2litre Multi-Way 16 22nd February 2006 09:58 AM
