#11 | |
Qts: .39 Vas: .133 ft^3 (3.78 L) Fs: 57 Fb: 40 (~.7*Fs) Line length would be 5.7 ft Inner pipe diameter would be 4.5" (5" PVC pipe should be used) Fibreglass stuffing -- 1/3 lb per ft^3 You could use 6" pvc pipe but the length would have to be 47" yielding an Fb of 57 (the driver's Fs) |
#12 |
Are the advantages of a tapered line relative to a 2-way speaker
system less, where the LF driver would be crossing over as high as 2500 Hz. Would a straight line be better overall? Jeff |
#13 |
I think that the advanyages of a tapered system listed above are still true for a two way crossed over to a tweeter. The 3/4 wavelength mode, and the other higher order wavelength modes, will be higher in frequency for a tapered TL where the stuffing is more effective at damping them out.
#14 |
Thanks Martin. I just assumed that a tapered line was superior.
My first pair of TL's are now 25 years old, so I'm a little out of the loop so to speak. After seeing the info on your site, I realize TL theory has changed dramatically. Jeff |
| ZD5 damping and transmission line questions. | gl | Multi-Way | 4 | 27th July 2007 03:26 PM |
| Transmission Line Questions | Matttcattt | Multi-Way | 32 | 13th July 2003 06:20 PM |
| Transmission Line Questions | Solid Snake | Multi-Way | 16 | 24th June 2003 01:28 PM |
| Just a few Transmission Line Questions | kneadle | Multi-Way | 10 | 16th January 2003 02:03 AM |
