Old 15th June 2005, 12:15 AM   #1
Madmike2's Avatar
Default Huge !
Man this is the biggest tweeter i have ever had it weights 2 pounds easy and as you can see it bigger then the CD case. I think i am in love. Till the 4 10's show up.
Persistence is better then intelligence. Unless persistence kills you.
Old 15th June 2005, 03:46 AM   #2
sdclc126's Avatar
What are these and what project are you putting them into?
Soft Dome
Old 15th June 2005, 03:57 AM   #3
Chaucer is offline Chaucer  United States
Account Disabled
Is that a Hi-Vi? If so, which?
Old 15th June 2005, 05:34 AM   #4
dshortt9's Avatar
Default TWEETER?
That's no tweeter! Here's a tweeter, all 12 pounds!
http://www.essspeakers.com/amt_1d.htm
Old 15th June 2005, 08:50 AM   #5
cph2000 is offline cph2000  Denmark
that is a cool tweeter. Do you know if the back plate can be removed ?
The purpose of this could be either:
- make it operate as a dipole
- place it a bigger designed enclosure to getter a wider frequency range (in the lower region). The f3 of this thing is rather high 1-2kHZ as I recall.
Old 15th June 2005, 10:54 AM   #6
Madmike2's Avatar
Hi-Vi RT8II ..... http://swanspeaker.com/product/htm/view.asp?id=18
Old 15th June 2005, 10:55 AM   #7
Madmike2's Avatar
Unfortunately i dont think it will even be x-over anywhere near that. I had a couple suggestions and i think ill let it live above 3k. The morel runs up that far.
Old 15th June 2005, 10:58 AM   #8
Madmike2's Avatar
Default Re: TWEETER?
Nice ! too bad i cant afford it
Old 15th June 2005, 11:15 AM   #9
Can you have a look and check if the back plate can be removed ? If crossing over as high as 3kHZ, you might be better of with a smaller planar or ribbon. Judging from the size of it your tweeter, it looks more like a midrange, thus beeming at higher frequences might be an issue, it might also lack a little in the very top end.
Old 16th June 2005, 12:45 AM   #10
Madmike2's Avatar
It is a mid/tweet. Beaming in a ribbon i have never heard of and ya the plate comes off, i am not going to take it off though
I am only crossing over so high to avoid the verboden region where no crossover is supposed to go. Kinda like space.
By the frequency response curves given i think the roll off near 18k wont bother me much. I wanted fast to match a fast woofer which matches my fast subs. Pretty low moving mass on the 10's i bought. If it all falls to peices and after a few months i cant get it sounding right ill rebuild it or buy a super tweeter and play with it that way.
project: HUGE dangerous dan Multi-Way 21 28th November 2005 12:45 AM
Think these are useful -- huge xformer?! rif Parts 21 13th August 2004 10:00 PM
HUGE Heatsinks bigparsnip Parts 0 22nd May 2003 08:14 PM
Page generated in 0.13030 seconds (69.78% PHP - 30.22% MySQL) with 11 queries
