Last questions about this
Old 13th June 2005, 12:43 AM   #1
Madmike2 is offline Madmike2  Canada
Madmike2's Avatar
Default Last questions about this
Ok this is the last i am going to bring up this project of mine till its done and i have pictures of the things working, not the boxes in various states of finish.
The system will consist of 6 enclosures total.
2 x 2 D10.8 enclosures for a total of 4 10's in stereo
2 x 1 Vifa wood fibre 7 " for Mid bass
2 x 1 Morel MW166 mated to RT8II ribbons with a single passive to seperate them
So, here is the gist of the question. I like my old rock. I like alot of the new. I appreciate classical when it sounds 'full' and i occaisionally like to rock the socks off the old lady down the hall.
Should i be running the 10's above 100 and rolling the 7" to 300 and the rest of it taking it up to 20k ?
Suggestions?
Persistence is better then intelligence. Unless persistence kills you.
Old 13th June 2005, 01:33 AM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
No, you should run the 10's to 300 and eliminate the 7's.
Old 13th June 2005, 03:38 AM   #3
tleonard is offline tleonard
Default I'd have to agree
I'd have to agree with Bill on this one... Looking at the response curves on your 10", the appear very flat to 550Hz or so... Running them to 300-400 should work fine...
Given your're running FOUR of these beasts, why mess with the 7" and the associated crossover complexities?
travis
Old 13th June 2005, 04:34 AM   #4
Now that I've had a chance to look at the specs of the Morel and ribbon tweeter, I change my recommendation.
Use 2 Morels, MTM style and high pass them at 12db/o at the F3 they assume when they are in sealed boxes with a Q of .7. The low pass to the woofers should be at this same F3.
Old 13th June 2005, 01:57 PM   #5
Madmike2's Avatar
hmmmm i never thought of that. I can sell these vifas to the guy who bought the other two no problem. It would mean trashing an enclosure and building another. The first suggestion seems to make more sense. Run the 10's up. I also never thought of that. I am used to 15 - 18 to 10 - 8 and then horns for pro stuff setups. If you think big think bigger.
Thank you BIll and Leonard. Bill, i am buying a camera i wont use my web cam to take bad pictures any more. I cant sleep with you mad at me
Old 13th June 2005, 02:33 PM   #6
Default Digital Camera
I hadn't thought of the fact that coming from the pro-audio set you came up with those size 'steps' - but that absolutely makes sense from what I've seen of pro audio equipment. Certainly not necessary here...
Just remember to resize the images from your new digital camera before you post or you'll endure the rath of the modem set (including Bill)...
travis
Old 13th June 2005, 03:33 PM   #7
Madmike2's Avatar
I just use Photoshop to "savefortheweb" the web cam i have is 1.5 MP so its not bad just limited in what i can snap. I dont normally have a use for a camera. Anyone takes my photo i usually take em down and wrestle it off of them. I almost lost one though. 85 year old woman with Tai Chi training. Choked me out before i could get the camera. Thankfully my 9 year old neice in Tae Kwon Do dropped her and escaped so we could destroy the negatives.
Old 13th June 2005, 10:20 PM   #8
Madmike2's Avatar
A couple shots of the 'top' end no drivers in and not fixed for teminals yet as i am debating active power. Not sure what looks good on Birch either. Tobacco stain or just a slight Cherry. These will have the Morel and the Hi-Vi.
Old 13th June 2005, 11:03 PM   #9
If you stain them with tobacco juice your room will smell like a cheap bar for months.
How about a nice Hummer yellow paint job?
Old 13th June 2005, 11:12 PM   #10
Madmike2's Avatar
LOL i meant the colour tobacco. not actual tobacco juice thats sick. Yellow is not my colour unless its on a ferrari.
Last questions about thisHide this!Advertise here!
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
PSU for QSC amp questions rkc7 Parts 5 10th November 2005 05:18 PM
sub questions kejolly Subwoofers 1 3rd November 2005 01:17 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
Copyright ©1999-2017 diyAudio
