I used to fix loudspeaker on wooden/MDF box with self-threaded screws. Every time I remove the loudspeaker for adjustment, the screw takes away some wood. Eventually the screws do not get tight enough.
If I use a threaded metal ring at the back of the wood with threaded holes on the ring and the screw goes through the wood and tighten on the metal ring, would it affects the sound |
#3 |
Whenever this happened to me and I was too lazy to go the T-Nut route, I would line the holes with epoxy and let dry. Then simply rethread the screws. Worked like a charm.
Mark |
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 12:27 PM |
| Fixing the R30 | bjackson | Multi-Way | 3 | 16th May 2010 06:10 AM |
| Need some help fixing this amp | mazeroth | Solid State | 1 | 13th May 2008 03:04 AM |
| Need Help Fixing an old NAD 304 | li_gangyi | Solid State | 14 | 8th December 2004 07:59 PM |
| Help! Fixing Amp. | shajan | Solid State | 20 | 29th May 2004 08:06 AM |
| Page generated in 0.06611 seconds (65.69% PHP - 34.31% MySQL) with 11 queries |
