Old 15th June 2005, 04:49 PM   #41
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Originally posted by Madmike2
HMmmmmmmmmm and if i STILL dont like it i can sand it back to plain wood again start fresh. Good call on the au naturel
easier said than done, but yet.
Old 15th June 2005, 05:40 PM   #42
cfb is offline cfb  United States
Two companies to look at for a wide variety of professional wood finishing supplies are STAR and Mohawk in fact “wood finish supply” has a clearance sale on some STAR products this month, June 2005, you might check out their list in case you can’t find the supplies locally http://www.woodfinishsupply.com/StarBase.html
The STAR company lists their distributors at http://www.starfinishing.com/distributor.asp
used to be commercial sales only but their distributors can sell to the individual hobbyist now.
and Mohawk at http://www.mohawk-finishing.com/dist_lookup.asp
I believe both companies are owned by RPM now.
Old 15th June 2005, 06:30 PM   #43
Oil based pigments doesn`t work well mixed with shellac.
As dhendryp stated, alcohol soluble aniline dyes works fine, for best results make the first and last steps without the dye.
Peter
Old 15th June 2005, 06:34 PM   #44
Sorry, i misspelled dhenryp
Old 15th June 2005, 08:10 PM   #45
Speakerholic
Cal Weldon's Avatar
Originally posted by robertG
Incompatible does not mean it cannot coexist. .
It sounded to me like you were saying they don't mix when in fact that's exactly how you get petroleum and water to mix.
My apologies if that's not what you were saying.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
lead vs sand IZHAKKATZ Analogue Source 15 4th November 2004 04:21 PM
Sand sandwich Vikash Multi-Way 48 10th April 2004 04:13 PM
Epoxy + sand for speakers? mulebarn Multi-Way 13 26th February 2004 04:29 AM
Copyright ©1999-2013 diyAudio
