paint sand paint sand .... - Page 4 - diyAudio
Old 14th June 2005, 11:52 PM   #31
Speakerholic
Cal Weldon's Avatar
sdclc126 and Bill Fitzpatrick:
The last two posts have been sent to Texas. That is the last sniping I wish to see from either of you today. Let's just move on...
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th June 2005, 12:55 AM   #32
Madmike2's Avatar
I love that site. Took a bit to read it and i think that pumice thing is something i would like to try. Not this time but next time. Can i add a slight pigment to the shelac without affecting its drying properties?
Persistence is better then intelligence. Unless persistence kills you.
Old 15th June 2005, 01:19 AM   #33
robertG is offline robertG  Canada
I'm not sure how pigment would react with shellac. One thing for sure, pigment would have to be in powder form.
Shellac is made with alcohol, which is incompatible with both water and oil.
On the other hand, you can test it by preparing a small batch...
Shellac flakes comes in three "flavors": clear (or pale), orange and dark (or red). For frecnh polishing, the pale or clear one is usually used.
Old 15th June 2005, 01:26 AM   #34
dhenryp is offline dhenryp  United States
You can buy alcohol soluble aniline dye. A google will get you many sources.
Old 15th June 2005, 01:29 AM   #35
Madmike2's Avatar
Orange sounds promising then i dont have to screw around and ruin something perfectly acceptable as it is. That would add some colour to this otherwise plain wood.
Old 15th June 2005, 01:55 AM   #36
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
actually, wood can look awesome once its got some shellac or lacquer on it... my preamp faceplate looked pretty bland before i started working with it. it looked like boring old oak or something, but it came out awesome. proper finishing really brings out the beauty in wood.
Old 15th June 2005, 02:05 AM   #37
Madmike2's Avatar
HMmmmmmmmmm and if i STILL dont like it i can sand it back to plain wood again start fresh. Good call on the au naturel
Old 15th June 2005, 02:06 AM   #38
Speakerholic
Cal Weldon's Avatar
Alcohol is an emulsifier which will mix with both oil and water. That why it's used for gas line antifreeze among other things.
Cal
Old 15th June 2005, 12:59 PM   #39
Cal
Look, prepared shellac has to be ditched after 6 month because air humidity (as in water) gets into the preparation.
Oil is used to apply the stuff with a rag and won't interfere in any way with shellac, it just accumulate on top of the finish and then can be removed.
Incompatible does not mean it cannot coexist. Hey I'm incompatible with my mother in law...
Old 15th June 2005, 01:23 PM   #40
Jennice is offline Jennice  Denmark
... Hey I'm incompatible with my mother in law...
Seems to be a fairly common phenomenon.
Then again, time tends to solve the co-existence dilemma.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 02:14 AM
lead vs sand IZHAKKATZ Analogue Source 15 4th November 2004 05:21 PM
Sand sandwich Vikash Multi-Way 48 10th April 2004 05:13 PM
Epoxy + sand for speakers? mulebarn Multi-Way 13 26th February 2004 05:29 AM
Copyright 1999-2017 diyAudio
