2 way speaker kit upgrade advice
Old 8th June 2005, 11:47 PM   #1
mark0311 is offline mark0311  Australia
Default 2 way speaker kit upgrade advice
Purchased 2 way Peerless DIY bookshelf system from the web. Construction first class but find the system harsh especially in treble area/higher freq. Would like some advice on upgrading ie tweeter/crossover design etc.
Specs
woofer... peerless 850122 6.5 CSX176H
http://www.d-s-t.com/link/peerless/data/850122.htm
tweeter..peerless 811827 25mm Dome Tweeter DT 100.http://www.d-s-t.com/link/peerless/data/811827.htm
rear vented, impedance 8ohms
Freq response 40Hz-20khz -3/+2db
sensitivity 88db
crossover freq 2700Hz
type 2nd order (12Db/octave) bessel filter
solen SCR capaictors,non-inductive resitors
dimensions 470 H x 220 W x 325 D 25mm mdf
full cabinet bracing,panel damping
volume 19 liters
port diameter 50mm
port length 90mm
port tuning freq 43hz
Old 9th June 2005, 05:45 PM   #2
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
It looks like you want to rework the crossover. Do you have measurement equipment?
Old 9th June 2005, 08:45 PM   #3
Re-working the crossover is probably the first step... I don't have measuring equip but new to this so happy to be steered in the right direction.... cheers mark
Old 9th June 2005, 10:46 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Wow, it's unreal how much those speakers are equal to the pair of bookshelfs I built. There are a couple differences:
I use 2700Hz butterworth filter instead of bessel.
I use the non-ferrofluid version of the tweeter.
Either way, I thought I would help out a little by posting my crossover schematic. If your tweeter uses a simple L-pad for the attenuation, all you need to do is change 2 resistors to lower the tweeter level to something less harsh. I use 5dB of attenuation on the tweeter.
2-Way Crossover Network
Low-Pass (LP) Filter: 1 required
Type: 2nd-Order Butterworth
Desired Corner Frequency: 2700 Hz
High-Pass (HP) Filter: 1 required
C1 = 6.8 F, Polypropylene, 0.0003 ohms
C2 = 5.1 F, Polypropylene, 0.0002 ohms
L1 = 0.51 mH, Air Core(#16), 0.33 ohms
L2 = 0.68 mH, Air Core(#16), 0.38 ohms
Tweeter
Impedance EQ
Req = 6.8 ohms
Ce = 2.1 F
L-Pad: 5.00 dB
Rp1 = 2.407 ohms
Rp2 = 7.067 ohms
Woofer
Impedance EQ
Req = 7.5 ohms
Ce = 22 F
The power of Science compels you!
2 way speaker kit upgrade adviceHide this!Advertise here!
Big upgrade of Neptune 820! Need some advice... rice'n'beans Solid State 2 15th October 2012 02:30 PM
LM3886 based Amp -Upgrade advice please. mikesnowdon Chip Amps 3 26th October 2008 12:53 PM
Advice/Help - Cap upgrade dieselpower Tubes / Valves 6 19th June 2007 01:23 AM
Speaker Upgrade Advice Please Friends quasi Multi-Way 2 4th May 2007 03:35 AM
CD upgrade advice ultrachrome Digital Source 3 6th May 2004 05:14 PM
Copyright ©1999-2017 diyAudio
