I think I am, but I want to make sure i'm wiring my speakers correctly. I have 9, 8ohm drivers. I'm trying to wire them 4/3/2 in series. Then those 3 strings, in parallel to give me 7.38ohms. Is my crude schematic correct?
#2 | |
Just to make sure I understand: you have 9 drivers, each 8 ohms nominal. So what are those resistance numbers in the drawing? If I had 9 times 8 ohms, I would wire 3 each in series, that gives each string of three 24 ohms. Then I would parallel those three strings, giving me, surprise, 8 ohms! If you have equal impedance drivers, and you wire them in different groups, you may get a 'good' impedance, but the drivers will have unequal loads and unequal loudness. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Anyway, what you want to do is the following:
Jan Didden
#4 |
9 drivers is kinda an odd number to be dealing with here. janneman's illustration is right though, I guess....
The golden rule of DIY: Build nice, or build twice! |
#5 |
I labeled them according to thier series impedance.
8-8-8-8 = 32ohm 8-8-8 = 24ohm 8-8 = 16ohm It's my understanding power tapering of line arrays improves the sound quality. Albeit my line isn't terribly long. |
#6 | |
Jan Didden
#7 |
I have no power tapering in my NSB array using 16 and there is no sound quality issues because of it. Try a simple wiring method first before you do an exotic one. Bring each NSB wire to a terminal block
so you can configure your wiring method by jumpering wires on the other side of the terminal block. I also read on another forum someone tried tapering on their NSB then went back to non-tapered and liked it better. There is no absolutes, just try. ie, http://www.lusty-blundell.co.nz/eweb...ck%2020Amp.jpg |
#8 |
The point of power tapering is to anchor the sound more towards the middle of the array, so really you are looking for a symmetrical layout with the outer speakers tapered down a bit.
What you are suggesting with the 4,3,2, config will not achieve this purpose. Go with 3 lots of 3 in a short array or get an extra driver each side and taper 3/2/2/3 |
#9 |
I am actually putting the higher output drivers in the middle. In terms of differences of output, my line will like like this.
In decibels +0 +0 +1.25 +3 +3 +1.25 +1.25 +0 +0 Worst case scenario I rewire them so they all have the same output. |
| Tapering TL-speaker, why? | MJ Dijkstra | Multi-Way | 0 | 25th February 2007 05:40 PM |
| How to correctly connect 24vdc battery power to Teac A-L700P??? HELP!!! | Crazy_D | Class D | 2 | 10th October 2005 07:16 PM |
| Bessel Or power tapering? | 24kilo | Multi-Way | 13 | 2nd October 2005 04:57 PM |
| TL Tapering - quick question | bigwill | Subwoofers | 26 | 28th April 2005 04:35 AM |
| Help with Line Array wiring_Power tapering | sqlkev | Multi-Way | 20 | 24th July 2004 07:32 AM |
| Page generated in 0.11441 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
