#11 |
Any time a conductor moves through a perpendicular magnetic field, eddy currents will circulate around the field line, absorbing energy. The higher the resistivity of the conductor the smaller the circulating currents and less energy absorbed. Titanium has both stiffness and low conductivity with a small increase in mass (approx 1.6 X that of Alum). Titanium is approx 1.5 x stiffer than alum. and if done right could be made abit thinner to help compensate for it's higher dencity.
#12 |
Thanks all..
Dan: Are there any acceptable constant tempco wire with low enough resitance used for voice coils?(except that, as I mentioned earlier, someone have a patent for some alloy for VC wire, just don't find the source when looking right now, have to come back later, if my memory serves me at all..) Do you use any kind of alloy wire for your products or just the common Copper and Aluminium? Pajazo: thats not the kind of source to look for, Titanium foils are very expensive, try goodfellow.com for yourself... But if anyone knows a cheap source for Titanium foils I would really like to take part of that information! Regards Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#13 |
Ultima,
There are two alloys that I know of, one patented by JBL and the other by Dr. Earl Geddes. Using either for voice coils would violate their patent. We use plain copper for 99% of all drivers; aluminum only when mass must be kept to an absolute minimum (it is less conductive than aluminum, meaning for a given DCR you get less BL with aluminum as compared to copper). Dan Wiggins Adire Audio® |
#14 |
By the way, Jordan used titanium in one of his 4 inch designs, marketed by Audio and Design in 1966/67. Cost even then did not seem an issue, but it was rather difficult for him to shape. An article in November 1966 Wireless World covers this. He claims better HF and transient response using this material, but I have not seen any listener reviews. I suspect different cone shaping gave him similar results with aluminium.
#15 |
Dan:
Yes, Geddes was the guy I had in mind, I did btw a search at USPTO with Geddes as inventor and came up with 153 hits, non of them talking about Low Thermal Compression Voice Coil, yet I found several other patents by the Earl G. Would be curious to know what the patent says as Copper Nickel alloy is nothing new, but maybe the "use" of it... RJB: I note your point regarding the cost, good question, was Titanium so much cheaper before, however I do admit I dont know the cheapest source. Or perhaps it was fake "Titanium", eg. heat treated Aluminium is also greyish. Regards Michael
#16 |
The Scanspeak 26w8861 10" woofer, which I use in my Delta, also uses a titanium former.
#17 |
I think most of the new revelator woofers from SS uses titanium formers. Accuton also use Ti in several new drivers.
A very good Swedish speaker manufacturer (Ino Audio) also uses Ti in some designs. /Peter |
#18 |
hi
Ultima - I think you need the Loudspeaker Industry Sourcebook the least - as it seems from your queries you are gearing up for production - all the best suranjan |
| Thermal Conductivity of Kapton Compared To Aluminum? | kelticwizard | Everything Else | 7 | 20th June 2007 06:23 AM |
| Voice Coil Formers... Kapton vs Nomex vs Aluminum vs GF/TIL | OlogyAudio | Multi-Way | 3 | 1st June 2007 03:27 AM |
| Aluminum Hookup Wire | jsa_ind | Everything Else | 14 | 13th January 2007 10:05 AM |
| Soldering wire to aluminum | eRiCdWoNg | The Lounge | 2 | 12th July 2004 02:20 PM |
| Page generated in 0.11751 seconds (77.94% PHP - 22.06% MySQL) with 10 queries |
