Old 3rd June 2005, 06:50 PM   #1
Pbassred's Avatar
Send a message via MSN to Pbassred
Default volume calculation
I don't get WINISD. I tell it the driver, it tells me the volume and draws a nice plot of what should happen. What if I don't want to use the ideal volume? I tell it the size I want to use but it draws exactly the same graph.
Its not calculating . Only showing library photos. . Tell me there's a calculator out there that calculates.
Jeeees! I only asked
www.davethebass.com
Old 3rd June 2005, 06:51 PM   #2
leadbelly's Avatar
No, you're using it wrong, give us specific examples of what you are doing and we can help.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 4th June 2005, 03:22 AM   #3
Default Re: volume calculation
There is a range of volumes that will give an essentially flat response, so you don't have to use the WinISD recommended volume.
WinISD does not give the same picture regardless of volume.
Here is graph of the Peerless 260 in two different enclosures, both tuned to 27.95 Hz.
Red is 113 liters.
Blue is 226 liters.
As you can see, same tuning, two different volumes, two different response curves.
As leadbelly said, please tell us which woofer, which Thiele-Small specs, and which size box you would like. We can help you from there.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 4th June 2005, 09:42 AM   #4
Pbassred's Avatar
Actually, It was just out of interest. The question was more of a "what will happen if....?" I am butchering a pair of old cabs to make monitor wedges for stage use. The cabs are only 22.5 ltr. and I have a pair of Audax AP210M0 8"
Impedance 8ohm
Résonance 46.38
Puissance RMS (iec) 50W
Sensibilité (2.83V/1m 90.2
Excursion 3.5mm
Qms 3.30
Qes 0.92
Qts 0.72
Vas 63.751
HIFI is not the requirement for these. In fact in a room already full of bass frequencies, the singer is more concerned with additional middle/high frequencies to guide them.
Just using the project as a learning experience.
www.davethebass.com
Old 4th June 2005, 12:33 PM   #5
Here you go. An Audax AP210MO in a 22.5 liter sealed cabinet.
You have a 4 dB or so hump at 100.
If you stuff the box full of stuffing, you might be able to take that hump down a bit. Or, you might just equalize.
-Anonymous
Old 4th June 2005, 06:58 PM   #6
Pbassred's Avatar
kelticwizard has attached this image:
Is it just me that can't see any images in this post ?
www.davethebass.com
Old 5th June 2005, 05:41 AM   #7
frugal-phile(tm)
planet10's Avatar
Or make it aperiodic.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th June 2005, 05:58 PM   #8
Pbassred's Avatar
What's the correct way?
www.davethebass.com
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Max SPL calculation? Ignite Multi-Way 17 9th April 2007 08:38 AM
Volume Displacement Calculation lovitz Multi-Way 5 11th March 2007 12:52 AM
Box volume calculation questions. Nappylady Subwoofers 2 29th March 2004 09:03 AM
Help with volume calculation andrew01 Multi-Way 2 1st July 2003 12:32 PM
Page generated in 0.09387 seconds (81.47% PHP - 18.53% MySQL) with 11 queries
