Account Disabled
Hi, I found two B&W drivers CWM650 and I want to combine them with Vifa D27TG-05-06. This is totaly new for me, I never made loudspeakers. Can U help with box design and suggest the crossover too
Here it is TS parameters for both drivers: Vifa D27TG-05-06: http://www.d-s-t.com/vifa/data/d27tg-05-06a.htm Nominal impedance [ohm] 6 Voice coil resistance [ohm] 4.6 Nominal power [W] 100 Short term max power [W] 400 Long term max power [W] 200 Operating power [W] 3.2 Sensitivity [dB] 92 Frequency range [kHz] 2.5-30 Free air resonance [Hz] 1000 Voice coil diameter [mm] 26 Voice coil height [mm] 1.6 Air gap height [mm] 2 Voice coil inductance [mH] - Eff. diaphragm Area [cm?] 7.1 Moving mass [g] 0.3 Magnet weight [g]/[oz] 240/8.5 Force factor [Bl] 2.7 VAS [l] 0.006 Qms 2.15 Qes 1.19 Qts 0.77 B&W CWM650: - Mechanical Parameters - Fs = 74Hz Qms = 4,653 Vas = 7,558 liters Cms = 0,332 mm/N Mms = 13,95 g Rms = 1,394 kg/s P-Dia = 127 mm Sd = 126,7 sq.cm - Electrical Parameters - Qes = 0,824 Re = 3,91 Ohm Le = 0,328 mH Z = 4 Ohm BL = 5.547 Tm Pe = 60 watts - Electromech. Parameters - Qts = 0,7 no = 0,358 % 1-W SPL = 87.69 dB 2.83-V SPL = 90.8 dB Thanks. |
#2 |
Account Disabled
...another view on B&W...
#3 |
Do you have any sugestion?
#4 |
What you think about Daline?Answer me please.
#5 |
Greets!
T/S specs? Anyway, Dalines work best with low Qts, Vas drivers, otherwise the cab can get really big. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
Here what i got.Driver is 6,5 inch 130w,8ohm.kevlar membrana.
B&W CWM650: - Mechanical Parameters - Fs = 74Hz Qms = 4,653 Vas = 7,558 liters Cms = 0,332 mm/N Mms = 13,95 g Rms = 1,394 kg/s P-Dia = 127 mm Sd = 126,7 sq.cm - Electrical Parameters - Qes = 0,824 Re = 3,91 Ohm Le = 0,328 mH Z = 4 Ohm BL = 5.547 Tm Pe = 60 watts - Electromech. Parameters - Qts = 0,7 no = 0,358 % 1-W SPL = 87.69 dB 2.83-V SPL = 90.8 dB |
#7 |
frugal-phile(tm)
Nice looking driver (for the yellow kevlar look). Qt is high for any BR enclousre, but the parameters look decent for an alpha TL.
Here is a small spreadsheet GM did for calculating an alpha TL. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Greets!
I'm curious where you found these, all I found in a search was an in-wall speaker with just basic specs. Anyway, these are best suited for a relatively large sealed cab or well stuffed (~aperiodic) TL to mimic an IB. Frankly, considering the high Fs, sticking it in a 1-1.5 ft^3 sealed cab is what I'd do. If you want a TL, then Rick's Alpha TL design tuned to ~104 Hz is as good as any for a ~compact cab: L = 29.21" CSA (w x d) = 73.613"^2 Stuff to suit, a sim suggests 36 oz distributed along ~80% of the line or a bit more if a more IB like response is desired. For sure it's not suitable for a Daline. With no Xmax given, no idea what the excursion limited power might be. GM
#9 | |
Oops! I forgot I was supposed to make the spreadsheet more user friendly. Maybe I'll have some time this week. At least it's on my long 'to do' list now. GM
#10 |
The golden rule of DIY: Build nice, or build twice! |
| Studio monitor speakers as Hi Fi speakers? | MRod | Multi-Way | 2 | 27th March 2009 05:07 AM |
| Built differences between Guitar Speakers and PA Speakers? | agadis | PA Systems | 7 | 24th September 2007 08:22 AM |
| FS : Studio One Pi Speakers aka Fred's EZ speakers | Cacophonix | Swap Meet | 6 | 10th September 2007 10:56 PM |
| How would you compare your DIY speakers to commercial speakers? | AJ Bertelson | Multi-Way | 20 | 28th May 2004 03:20 PM |
| Page generated in 0.11198 seconds (76.73% PHP - 23.27% MySQL) with 11 queries |
