Totem Arro Clone - Page 3 - diyAudio
Old 1st October 2002, 07:09 AM   #21
frugal-phile(tm)
planet10's Avatar
Originally posted by navin
Dave is right about Qts too. very high Qts is not too good.
It isn't too high to be good, it is too high to be in a vented box. It would be interesting to see what could be had out of it in a ML-TQWT.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st October 2002, 08:34 AM   #22
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
vented or TL or any other such variant requires that the woofer be able to damp itself as the box is not there to act like a srping.
this means it is preferable for drivers being used in vented or TL to have a lower Q (lower than 0.5 is the norm and often lower than that).
in both a TL as well as a vented box the back wave of teh driver is ot absorbed, as it is done in a selaed box, but allowed to exit the box.
ML... is also a variant of TL right?
...still looking for the holy grail.
Old 1st October 2002, 11:48 AM   #23
FrankDIY's Avatar
Default Re: Re: Still me...
Originally posted by planet10
It may well go that low at low signal levels, but will be excursion limited pretty early.
dave
Hum, I didn't think about that. Good point.
I also prefer the '102 because the Q is lower. The freq. response for this driver is:
I think I will stick with this driver
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 1st October 2002, 11:53 AM   #24
FrankDIY's Avatar
dave
It is cheap to try, Solen have them for 40$ (CDN)
Old 1st October 2002, 05:30 PM   #25
frugal-phile(tm)
planet10's Avatar
A TL is usually by its nature well damped. A TL likes a Q of 0.3-0.5 or so. A ML-TQWT is a variant of the Voigt pipe (aka TQWT, TQWP -- these like a Q of 0.45-0.7 or so) that actually works. Both the TL & the Voigt are subsets of speakers best classed as quarter-wave enclosures where a 1/4 wave pipe is used in an attempt to enhance the bass and damp the cones resonance at Fs.
Critically damped is a Q of 0.707. Any driver in this range will have its inherent Q when mounted on an open baffle. Qs higher than this tend to be underdamped. They can still provide good results. I had some salvaged 6" with a Q of 1.1. I put them in a box of over 2 cu ft and loaded them aperiodically and they sound pretty good (cap XO to an open back Audax 25mm dome)
dave
Old 1st October 2002, 05:58 PM   #26
navin's Avatar
many car woofers have high Qs; i suspect the deginers of these drivers expect aperiodic loading of a car door or a very large sealed box like a trunk.
dynaudio used to make high Q drivers too and then use the aperiodic vent to reduce the Qts.
what i was trying to ask / say is....
if the back of the driver is loaded by a bass relfex box, or 1/4 wave pipe or such system instead of a sealed box (small) there is no "sping" effect of the sealed box to keep the cone in check so the driver must be able to do this without the help of a box. the driver of a TL, vented box etc... should be designed not to need the spring effect of a sealed box. these drivers normally have low Qs. Focal tends to make such drivers.
Old 1st October 2002, 06:19 PM   #27
frugal-phile(tm)
planet10's Avatar
A TL is damped by the lines quarter-wave resonance. A vented box is damped by the air inside except around the Fb where the driver becomes "unloaded"
dave
Old 26th October 2002, 08:45 PM   #28
FrankDIY's Avatar
Talking Ok, now it is time to bring back this thread to life...
Almost all the wood is cut, I got all the drivers and the crossover parts.
Totem specs says that they use a Linkwitz-Reiley "optimized" crossover. I interpret "optimized" as a normal Linkwitz-Reiley crossover + an impedance compensation network for the drivers. Do yo agree?? Anyway, I will try both.
Apparently Totem uses paper-oil bypass caps. Do you think the sound will be very different if I don't use this? I doubt but it should be interesting to experiment. The bad thing is that these caps are quite expensive (I need 4). What do you think?
Old 17th November 2002, 01:19 PM   #29
FrankDIY's Avatar
Default DIY progress...
Few pictures on the progress. The front baffle is fixed only with screws to tweak the system until the last minute. It is now time to design the crossover, party!
Click the image to open in full size. Click the image to open in full size.^Click the image to open in full size.
Old 28th January 2003, 02:10 AM   #30
FrankDIY's Avatar
The veneer is now finished. One of the channel is painted. I need to install the black feet and the crossover and ... that is all!!
The Clarro alias Totem Arro Clone. Finished!! FrankDIY Multi-Way 26 9th February 2010 03:47 AM
My Totem Arro 4 ohm load on KT-88 based amp r3cc0s Tubes / Valves 9 15th May 2008 06:45 AM
filter Totem Arro clone,please help ACQUA Multi-Way 2 23rd February 2007 07:48 PM
Totem arro clone ACQUA Multi-Way 3 18th January 2007 10:07 AM
Totem Shaman Clone? JohanH Multi-Way 15 22nd January 2006 09:04 PM
Copyright 1999-2017 diyAudio
