The following High-Pass passive network for TAD 4001 use a 2.7uF capacitor. Any one know the effects of this capacitor? Thanks in advance.
My TAD Horn Cinema |
#2 |
This is normally used to reduce HF impedance so that high frequency is balanced. Just a guess!
Any other comments?
Hear the real thing! |
#3 |
Likely to lift the upper end
#4 |
Greets!
Right, this is a HF bypass cap to 'lift' up the HF to counteract the shelving due to the series resistance. Standard CD horn EQ. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
Thanks GM,Feyz,Soongsc!!
Is there any formula to calculate the frequency where lifting begin and the values of capacitor?
#6 |
I would recommend using a simple SPICE program to do some simulation, and just look at the results.
| Tad 4001 , ET-703 integration | limono | Multi-Way | 7 | 28th November 2010 09:17 PM |
| Please help with the designing of a passive crossover network! | Big_Bill | Multi-Way | 74 | 17th July 2009 04:53 AM |
| passive network Z interaction for FR with helper | freddi | Full Range | 1 | 28th February 2009 06:29 AM |
| E-speakers 4001-1601 ref. | kartsmart | Multi-Way | 9 | 9th September 2005 09:27 PM |
| Usable frequency response for TAD 4001 | Rocky | Multi-Way | 57 | 1st June 2004 05:20 PM |
| Page generated in 0.09441 seconds (76.32% PHP - 23.68% MySQL) with 11 queries |
