Wanting to build a line array. Newbie troubles with impedance and efficiencies. - Page 2 - diyAudio
Old 30th May 2005, 05:12 AM   #11
GuyPanico's Avatar
After some more reading, and pondering, and figuring, here's what I have.
9 woofers, power tapered, 111.3mm CTC, 95.85dB theoretical sensitivity.
5 tweeters, power tapered(out of necessity), 38.2mm CTC, 99.44dB theoretical sensitivity.
One wavelength spacing on the woofers should be about 2950. With the xover (12dB) at 2500hz, that shouldn't be a problem I dont think. However with the tweeter spacing, effects will start to occur around 8950hz(1wavelength)
While the tweeters FR graph appears to do well from 2k+, it states 3.5-20k under it's description. So I hope i'm not asking too much out of these tweeters.
I'm also thinking about trying OB. Although my room isn't optimally layed out for it. If it fails i'm not out much and i'll try a ported cabinet tuned to maybe 95-100hz.
I think i'm on the right track now.
Old 30th May 2005, 09:36 PM   #12
Guy,
I think you are on the right track. Your design seems to get the most out of the drivers that you have in mind.
Yes, you can try the OB first but you'll have very little bass and would need likely stereo subwoofers crossed fairly high to mesh. As you say though, you can always port the cabinet.
Jim
Old 14th July 2009, 03:50 PM   #13
i am going to make some with 4" mids what hf driver does anyone recommend
Old 14th September 2011, 10:56 AM   #14
alspe is offline alspe  Finland
Which configuration it is possible to compensate baffle step loss by adding more woofers to 0,5-way? One woofer parallel to midbass woofer gives 10 LOG2 + 10 log (8/4) = 6 dB gain to bass region (which is maximum that can be used, I think).
Is it possible at all to add more than one woofer to 0,5-way for one midbass (using same woofers)?
Full Range Line array Efficiency and Impedance Question? rjp366 Full Range 10 23rd August 2009 07:42 PM
I want to build a line array... Znyper Multi-Way 46 8th December 2007 11:45 PM
Line Array Impedance HELP Dominick22 Full Range 7 21st June 2007 12:48 PM
Newbie, wanting to build Amp PaulHilgeman Solid State 3 8th January 2003 03:24 AM
Copyright 1999-2017 diyAudio
