I have 2 Vifa P13WH's (8 ohms in paralell = 4 ohms) in an MTM arrangement with a Vifa XT25 (4 ohms).
I need a frequency response simulation based on the following XO points: P13's are connected to the amplifier via the following in series: 1) 0.3mH 2) 55uF The XT25 is simply a 4.7uF polypropylene. Based on the cross over freq's, what kind of response am I getting... ear tells me I need to attenuate XT25 by 2-3 db... Thank you a bunch in advance.... SOS to Dave as well. |
#2 |
Why dont you do this yourself? Unless we have measured responses from your cabinets with the drivers in them results will be innacurate to say the least.
As we dont have this what will be involved is someone going to all the effort of making frd and zmas from SPLtrace, this you can do. And you can model with them on Aduas speaker workshop.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
Where Does one get, "Aduas speaker workshop"?
Also this is an open baffle, so the enclusure is not a biggie in this case. |
#4 | |
Being an openbaffle is not much of a consequence unless you are looking to see what happens at the lower end of the speakers response.
#5 |
Have you tried "Audua"?
Hear the real thing! |
#6 | |
I am not worried about the response below 400Hz just above, based on driver sensitivities and my crossover points, I need to know if there are suck-outs or bumps from 400Hz to 40kHz. |
#7 | |
#8 | |
http://home1.stofanet.dk/troels.gravesen/ scroll almost to the bottom of the page.
#9 |
On the contrary:
http://home1.stofanet.dk/troels.grav...ndex_b/OBS.htm I made my open baffle based on diagram G: at the bottom of that page.... |
#10 |
Ah I see. I would go with H. Just for you information I have made an open baffle actually with the W15CY001 used here that is just over 30cm wide. A sort of cross between C and E, measured result? an exact replica of what is written here.
I think I read and posted about dont mounting in the centre because I had looked here before and thought H would be best for my situation. Here is my measurement of the W15 in a 30cm open baffle, with a 2nd order 300hz hp and 3rd order 3000hz lp.
| How to simulate OPT in LTspice? | Akita | Tubes / Valves | 14 | 26th June 2010 12:05 AM |
| Please simulate my headphone amp | Nico Ras | Headphone Systems | 55 | 1st April 2008 09:01 PM |
| Need some help to simulate Aleph 5 | guitvinny | Pass Labs | 7 | 1st January 2008 03:11 PM |
| Someone willing to simulate a TL for me? | tubee | Multi-Way | 21 | 27th November 2007 02:25 PM |
| Paid to simulate | steve_mak | Solid State | 3 | 8th July 2007 05:34 AM |
| Page generated in 0.11292 seconds (76.85% PHP - 23.15% MySQL) with 11 queries |
