Old 29th May 2005, 05:04 PM   #11
The modfication of the PT2 sounds very simple but is a b.... to execute. It all comes down to this, the PT2 has some bad inner damping. The cavity behind the mylar foil has to be damped with felt (I hope this is the correct translation of the dutch word "vilt").
The results can be seen in these pics.
Old 29th May 2005, 05:18 PM   #12
And, here is the decaygrafic of the normal version
Old 29th May 2005, 05:29 PM   #13
And, the decaygrafic of the modified Pt2
Old 29th May 2005, 05:33 PM   #14
As you can see, the frequency response is improved, it can now be easily xovered at 2,5 hz or even 2khz.
In the decaygrafic you can see how much the resonancefrequency decay has been improved.
Oh, one more thing. This mod seen here is done with the old version of the Pt2.
Soon I'll be posting the 1st results of the new version of the Pt2.
Old 29th May 2005, 09:20 PM   #15
Paul W is offline Paul W  United States
Paul W's Avatar
mazeroth,
Here's a link...
4-way OB
Old 29th May 2005, 09:32 PM   #16
Paul W's Avatar
...and here is the next generation which, if I get up early enough, may be running tomorrow. (the guy on the right is just a test proto, the other one is final-in-process)
As you can see I like the OB/IB combo enough to do it again.
Old 30th May 2005, 01:46 AM   #17
Interesting Paul! What are you doing? Loading a line-source ribbon with a waveguide? What drivers are you using?
Old 30th May 2005, 08:21 PM   #18
I'm playing around with some of the monsoon planar drivers in a more-or-less OS waveguide, and my initial results are very promising. I'm hoping to have my 'more advanced prototypes' making noise tomorrow. The combination of controlled directivity and better LF loading for a lower xover freq make this a great combo. I think the BG's could also benefit.
Makes for pretty honkin' big speakers, though.
Old 30th May 2005, 10:26 PM   #19
Paul W's Avatar
Yes, ribbon with a little guidance. The "first final" is much more shallow than the proto in that picture...at least on that baffle it was too directional.
Drivers are W26's and a scratch 1" x 45" x 5 micron ribbon.
Old 31st May 2005, 03:40 PM   #20
What kind of dispersion are you expecting from with that waveguide??
any noticable SQ deficencies vs. without a waveguide?
Dayton PT2B-8 good tweeter for line array use? thadman Multi-Way 3 13th September 2011 04:51 AM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
Pros and Cons of Transmission Line speakers Bedroc Multi-Way 60 28th March 2007 03:34 AM
pros & Cons 0f an open back array tolits Multi-Way 2 28th October 2005 08:42 AM
Line Array: NSB + Dayton PT2B Planar Tweeter ? thylantyr Multi-Way 5 27th January 2005 04:33 AM
Copyright ©1999-2013 diyAudio
