6.5/7inch midbass recommendations - Page 2 - diyAudio
Old 31st May 2005, 02:30 PM   #11
Originally posted by AntM
Is this a recently bought unit? I wonder if there were production changes.
I've had my speakers for about a half year. I was planning of using them in a ported cabinet of 17l netto tuned at 41Hz using a br-pipe with 6cm diameter and 24cm length (flared).
A friend of mine uses these woofers in a 16l netto cabinet tuned at 43Hz using a br-pipe with 5cm diameter and 15cm length. I listened to his speakers before deciding on building mine but found the br-pipe getting a little noisy on loud levels (very loud!) so I decided to make mine a bit wider, flared and with pipe exiting on the back.
Originally posted by gustav
Hello everyone!
I once made a FR measurement of this Monacor driver (in IB).
The driver has serious problems in midband !
I did not use the driver. I would use the Focal or some other good driver instead.
Good luck!
Thank you for your contribution but I always find this very strange. A lot of people like this speaker and are happily listening to it. But in every thread about this speaker there are always some people that say it doesn't sound good/right or whatever. Can you show me some measurements or at least explain the problems that this driver has?
I do agree that the reputation this driver has for being very good up to 5Khz is a little exaggerated (as can be seen on the measurements of K+T) but I do think that it has great potential when crossed between 2Khz and 2,5Khz to a good tweeter. Especially for the price.
Old 31st May 2005, 03:16 PM   #12
audiobomber's Avatar
I don't know anything about Monacor except what I've read on the 'net, but I have to wonder about their quality control. It's possible that some versions are as good, and some are as bad, as people say.
Dan
Old 31st May 2005, 03:28 PM   #13
That's right: some units are good, others are better be left alone.
Units that are proven to be good are:
SPH-135KEP
SPH-165KEP
SPH-300KE
Old 31st May 2005, 06:52 PM   #14
Gustav wrote:
Hello everyone!
Good luck!
Wich driver, the 165kep?
What problem does it have in the midband then, show me.
I haves pair of Focal 7N515 7inch woofer for sale mertztan Swap Meet 0 7th January 2009 02:28 PM
Hi, and midbass recommendations that play low. timreeves Multi-Way 4 19th May 2008 03:05 AM
7inch headrest monitors - help... gaz100uk Car Audio 0 8th February 2006 02:08 PM
which midbass would be better? kan3 Multi-Way 0 6th January 2004 04:01 AM
Copyright 1999-2017 diyAudio
