#11 |
Here is what they sent me.:
items description Labyrinth Fronts Labyrinth Centre Labyrinth Rears loudspeaker System "3 way,bass reflex" "2 way,bass reflex" "2 way,bass reflex" Driver "4""x 1+1"" x 1+ 4 "" x 4" "1 "" x 1+ 4 "" x 2" "1""x 1+ 4 "" x 1" Finishing varnish varnish varnish Enclosure 15 mm MDF 15 mm MDF 15 mm MDF Grill black fabric black fabric black fabric Color white/silver/black white/silver/black white/silver/black Dimension(WxHxDmm) 140x1130x240 450x140x180 284x225x150 N.G(kg) 15 5 3 Carton Dimension (WxHxDmm) 325x215x1220 210x535x500 G.W(kg) 17 13 driver(tweeter) cone materials silk silk silk driver diameter(inch) "1""" "1""" "0.75""" magnet diameter(mm) 70mm 60mm 70mm magnet weight(g) 230 101g 150g magnetic shielding no yes no driver(midrange) cone materials paper driver diameter(inch) "4""" magnet diameter(mm) 80mm magnet weight(g) 360g magnetic shielding no basket iron surround rubber voice coil 25mm driver(woofer) cone materials white paper white paper white paper driver diameter(inch) "4""" "4""" "4""" magnet diameter(mm) 80mm 60mm 70mm magnet weight(g) 360g 101g x2 150g magnetic shielding no yes no basket iron iron iron surround rubber rubber rubber voice coil 25mm 25mm 25mm parameter rated impedance(Ohm) 8 8 8 power handling(W) 80 40 30 maximum power 120 60 45 frequency response(Hz) 50-20KHz 50-20KHz 60-20KHz sensitivity(dB) 89 87 87 crosover frequency(Hz) 1000Hz/3500Hz 4000Hz 4000Hz This is there top selling speaker |
#12 |
So? How do they sound?
The power of Science compels you! |
| looking for opinion | xxxwhezzy | Car Audio | 9 | 8th May 2008 03:53 PM |
| Opinion on a Mid | Madmike2 | Multi-Way | 1 | 9th May 2005 03:24 AM |
| Your opinion on 813? | Jax | Tubes / Valves | 5 | 16th January 2004 09:10 PM |
| Want your opinion! | vdi_nenna | Pass Labs | 9 | 16th January 2004 03:27 PM |
| I need your opinion.. | Richard Moon | Everything Else | 1 | 11th January 2004 06:14 AM |
| Page generated in 0.06505 seconds (72.73% PHP - 27.27% MySQL) with 10 queries |
