#31 | |
In any event, I promised a derivation, and here it is. Just to keep things clear, s = jw, where j is the root of -1 and w is omega, 2 * pi * frequency. As well, I'll use sqrt(x) for root of x. A(s), B(s), and so on are the representation of gain as a function of s. A first order low pass transfer function is 1/(s+1), and a first order high pass transfer function is s/(s+1), for w normalised to 1.0. Lowpass functions for denormalised frequencies are w/(s+w) to keep the gain = 1.0 at s = 0. One thing to remember, the absolute value of a complex expression is derived by the square root of the real and imaginary parts. For example, if we have (3 + 4j), then the absolute value is sqrt(3*3 + 4*4) = 5. Onward! We can model the baffle step by a constant transfer function added to a first order high pass filter: Eq.1: BS(s) = 1 + s/(s+1) Eq.2: BS(s) = (s+1)/(s+1) + s/(s+1) Eq.3: BS(s) = ((s+1) + s)/(s+1) = (2s+1)/(s+1) As it turns out, the -3db point is found at w = sqrt(1/2): Eq.4: BS(0.707j) = (2*sqrt(1/2)j + 1)/(sqrt(1/2)j + 1) Now we generate the absolute value by squaring the real and imaginary terms, summing them, then taking the root: Eq.5: abs(BS(0.707j)) = sqrt((2+1)/(1/2+1)) = sqrt(2) and sqrt(2) happens to be the amplitude which corresponds to +3 dB. That's all well and good, but how do we fix this? Looking at Eq.3, we can merely flip the fraction to get a good hint as where to go, because we want BS(s)*BSC(s) to be flat with respect to s: Eq.3: BS(s) = (2s+1)/(s+1) Eq.6: BSC(s) = (s+1)/(2s+1) Let's see what happens if we divide the bottom by 2 so we can keep the (s+1) terms intact for cancelling, yet restate the denominator in terms of s: Eq.7: BSC(s) = (s+1)/(s+1/2) That implies the correction might happen at w = 1/2, so let's see what the filter looks like, from the LPF form mentioned above: Eq:8: H(s) = (1/2)/(s + 1/2) And now we create a baffle step compensator by summing this lowpass filter with a constant gain of 1.0: Eq.9: BSC(s) = 1 + H(s) = 1 + (1/2)/(s + 1/2) = (s+1/2)/(s+1/2) + (1/2)/(s + 1/2) = ((s + 1/2) + 1/2) / (s+ 1/2) = (s+1)/(s+1/2) which is identical to Eq.7 above, so we have a perfect baffle step compensator. This implies the lowpass filter for one woofer needs a cutoff frequency half that of the equivalent filter formed by the baffle step, but remember from Eq.4 that the baffle -3 dB point is reached at sqrt(1/2), or 0.707, of the baffle filter, so the baffle step filter cutoff is actually (1/2)/sqrt(1/2) = sqrt(1/2) of the baffle -3dB point. The whole system depicted here has a gain of 2, but that's not a problem. Long story short, if your baffle has a 3 db step at 420 Hz, tune your crossover to first-order lowpass one woofer to 300 Hz, and run the other to the tweeter crossover point. Cheers, Francois. |
#32 | |
frugal-phile(tm)
I'll persuse that when i'm a bit less rushed... can i add that to the series of BS articles i have on my website? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#33 | |
Dan |
#34 | |
Dan |
#35 | |
A bit of hand-waving there, but I think it holds. |
#36 | |
frugal-phile(tm)
dave
#37 | |
Attribute that bad boy and we're golden. Mods, how do we get this under a title where people could see/use it? Thanks in advance, Francois. |
#38 | |
I didn't express myself all that well; the second paragraph was more or less independent of the first. Still, if you have a second order rolloff on the woofers, they'll be coming in too steeply below crossover to properly compensate for baffle step, ergo my guess at a 400 Hz peak. Francois. |
#39 | |
Dan |
#40 | |
First we know the 3dB efficiency gain when you double the drivers thing is true because it's verified experimentally by measuring power and SPL. Let me take a crack at explaining it. I've never really thought it through before so lets see if if works. Let's work with a voltage source amp. At a given frequency voltage is proportional to cone displacement (X). Pressure in Pascals is proportional to the volume of air moved (Vd) which is X times the cone area (Sd). Single 8 ohm driver 1 watt = 2.83 volts at 8 ohms X = 1 mm Sd = 100 cm^2 Vd = 10 cm^3 Two 8 ohm drivers in parallel ---> 4 ohm load 1 watt = 2.0 volts at 4 ohms X = 2/2.83 = .7 mm Sd = 200 cm^2 Vd = 14 cm^3 Two 8 ohm drivers in series ---> 16 ohm load 1 watt = 4.0 volts at 16 ohms Each series driver sees 2 volts X = 2/2.83 = .7 mm Sd = 200 cm^2 Vd = 14 cm^3 So at 1 watt, 2 drivers move 1.4 times more air than 1 driver, no matter how they are wired. The sound pressure will also increase 1.4x. Convert to relative SPL: SPL increase = 20*log(1.4) = 3dB. Make sense? |
| Attack of the mutant reflow toaster | peufeu | Parts | 18 | 18th September 2009 06:42 AM |
| Virus Attack Help | boris333 | Everything Else | 1 | 7th May 2009 02:10 PM |
| Gomyhit_com virus attack............ | ashok | Everything Else | 21 | 21st March 2008 05:45 PM |
| Mosfet Class A drive: Low voltage sharp attack Vgs :VS: Smooth gentle Vgs. | Brian Guralnick | Solid State | 9 | 20th April 2003 02:11 AM |
| Page generated in 0.14749 seconds (82.64% PHP - 17.36% MySQL) with 10 queries |
