#21 | |
OMG it worked. Maybe I did not do that ![]() Got about 90 Hz for the fs though. It does seems to be 4 ohm according to the graph(s), but measures a DCR of about 5.5 with my voltimeter. Is that possible? I keep getting a message that says "Invalid Frequency Range - Does not include full impedance peak" when I try to "estimate parameters."
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team |
#22 |
Download the excellent SW manual from here
It's great bedtime reading and explains a lot. I was as confused as you are before I went through it step by step.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#23 | |
I read about measuring impedance in free air and with added mass, then measured those two. The specs I got did not seem to be very accurate, here's a pic . Maybe it did not account for the wire inductance or capacitance correctly. Qes seems to be off by the most 1.05 instead of .43 from the specs on the page given before, http://www.mindspring.com/~audiolab/peerlspc.htm I did not calibrate my sound card also.
#24 |
I think the problem with the Qes is my card line-in and line-out were not set to the same volume and maybe partly because they were not calibrated. I wanted to say this incase some one else was going to say the same thing.
#25 |
A couple things, you said you read 5.5 ohms using your voltmeter. Is this a digital voltmeter, and what do you read in terms of resistance when you just short circuit the leads of the voltmeter? Usually you will read something like 1 ohms by just shorting the measurement cable leads. So you need to substract that amount from what you read when you measure the driver's DCR. I think there is something wrong there. From your picture of SW results it says you entered the Re value. Try also extracting the T/S parameters letting SW decide the Re value, and compare this value to what you measured with substracting the lead resistances. I would guess they would be close, and it would be somewhere or less than 4 ohms. I think you also said the model number on the drivers say it is 4 ohm model.
Another thing, I think you have the paper cone version, not poly. I think they coat the paper cones with a special coating that make it look like poly from outside, but as you said the back of the cone looks paper. It is a good thing that you are measuring the T/S params, it is not unusual that production specs are off from published specs. But such Qe value makes me think that there is something wrong with the Re value entered. |
#26 |
As a quick and dirty check on the Qts, (which is generally pretty close to the Qes, as well), you might try using either Speaker Workshop or Audiotester to do a quick frequency response test, especially below 300 Hz.
The SPL response at Fs, in relation to the midpoint, for Qts is: Qts = 20 Log Qts So at Qts = 0.7, the response is: 20 Log 0.7 = -3.1 dB down from the midpoint. I did some quick math-you can extrapolate whatever your SPL is at Fs. Qts = 0.5 Response at Fs = -6 dB Qts = 0.4 Response at Fs = -8 db Qts = 0.35 Response at Fs = -9.1 dB Qts = 0.3 Response at Fs = -10.5 dB Qts = 0.25 Response at Fs = -12 dB It's a quick way to either check your Qts measurements, or even to use to find them. Note-some woofers do have a little bit of an output resonance at Fs. So if there seems to be bump in the SPL response around Fs, just visualize where the rolloff curve is leading, and estimate from there. It usually is pretty effective.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#27 |
hello friends
I've been listenig to these speakers on the ground while break-in and wondering if i could just do an open baffle. Also they sound not that great. wouldn't that be great I say oh, you say I, I say revolution, and u say die die die
#28 |
The specs for the woofers don't match each other they also don't match the specs on this page http://www.mindspring.com/~audiolab/peerlspc.htm
They should match these specs somewhat fot the SKO130, I think, and each other. I did the measurements a lot of time with two different sound blaster cards and the woofers still come out like this. So I guess my question is - what does this mean?
#29 |
It looks like you have SKO130's. IMO the T/S params on the left of your picture matches very well with http://www.mindspring.com/~audiolab/peerlspc.htm.
The difference between your two units may not be that important when you model the box. The unit on the right has higher Fs, but at the same time a lower Vas, and higher Qts. These differences may cancel each other in a box. For example, if I remember correctly, for a sealed box if the ratio of Fs/Qts remains same, box volume stays same to give same box alignment. So I would suggest you to model the box with the T/S parameters that are on the left of your picture. Then change the driver parameters to the right ones, and look what happens to SPL using the same box. It may turn out the end result will be very similar between the two units. I haven't used those drivers, but I had read that they have very nice midrange. |
#30 |
I would almost rather use the published specs cause I don't think speaker workshop has calculated the right Qes for these woofers.
My resistor is suppose to be 10 ohm 1 or 2 % tolerance, but I could not measure it accurately. Also I used the added mass method and I estimated that a pennies plus the tape weigh 5.1 grams, but I'm not too sure. Also I could not calibrate my sound card.
| Peerless TA305F specs | joek | Multi-Way | 2 | 9th December 2011 10:58 PM |
| Request: Peerless driver specs | Mos Fetish | Multi-Way | 12 | 3rd February 2009 12:43 AM |
| Pic.s/Specs for Carver systems, Peerless 830341/830343 | fortyquid | Multi-Way | 1 | 3rd April 2008 03:30 PM |
| Need Specs On Peerless S-217d Audio Transformer | ARHAICAUDIO | Parts | 0 | 13th April 2006 02:37 AM |
| Peerless 832979, s93-125, s95-110 specs? | rumreich | Multi-Way | 3 | 17th March 2006 06:25 PM |
| Page generated in 0.13054 seconds (78.40% PHP - 21.60% MySQL) with 11 queries |
