diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Close to the Edge (http://www.diyaudio.com/forums/multi-way/57451-close-edge.html)
PeteMcK 17th May 2005 08:42 PM
Close to the Edge
2 Attachment(s)
Thanks to that amazing piece of software 'The Edge' I've made a simple Q&D OB. The Edge had the driver placed closed to one edge of the baffle, & although I was sceptical about this I tried it, and it worked amazingly well.
Now I want to know why I can't make the baffle like this?:
MethMan 18th May 2005 01:36 PM
Irregular polar response? Hard to eq. roll off?
454Casull 18th May 2005 03:55 PM
Mechanically unstable? ;)
PeteMcK 29th May 2005 09:48 PM
before...
2 Attachment(s)
sounded more forward in lower mids than my Peerless 850488's (in 4L boxes), but about the same amount of low end:
PeteMcK 29th May 2005 09:54 PM
after...
2 Attachment(s)
Immediately noticed an 'enclosed' feeling to the sound, not as good as the flat baffle (need to do more listening). Ameliorated a little by turning the corner to the front. Tried swapping L & R sides - immediately noticed an improvement in low end; so my time wasn't wasted. So for asymmetrical baffles, the long side should be on the inside?
planet10 30th May 2005 05:23 AM
What driver is that? 6x9?
dave
PeteMcK 31st May 2005 02:41 AM
Sony
Hi Dave,
Its a 165x65 cm unit out of an old Sony tape recorder,
sorry don't have the part # handy, but it sounds good & has a reasonably wide range; I'm planning to add piezo tweeters & 12" woofers when I sort out a good baffle shape (which will probably be an asymmetric pentagon); I'll Damar it as well.
Pete McK
planet10 31st May 2005 05:37 AM
Re: Sony
cm? That is a monster... i just scored some alnico ones 203x100mm
dave
PeteMcK 31st May 2005 06:18 AM
err..make that mm
sorry, much smaller.
Actually, I do have a pair of larger oval units of about the same vintage, Magnavox, a defunct Aussie brand I think. These are about 10" x 4", but don't have very good lows & squawky highs due to their whizzer. I've Damared the cones, and I'm going to try some car underseal on the accordion surround to see what change that makes (+ damp the whizzer or remove it).
planet10 31st May 2005 10:13 PM
Re: err..make that mm
I alsways put Magnavox in the US... my RH84 has magnavox OPTs....
dave
Resources saved on this page: MySQL 18.75%
