Old 3rd September 2002, 10:04 PM   #1
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Pictures of my Thor project
Well, I have started building Thor with a couple of friends. I am building Thor by using .75" mdf covered with .75" oak. The internal dimensions are exactly the same and the external dimensions are .5" bigger on all sides.
http://brian.darg.net/thor
Brian
Old 3rd September 2002, 10:22 PM   #2
BrianGT's Avatar
in various stages..
Brian
Old 3rd September 2002, 10:24 PM   #3
BrianGT's Avatar
Post as an attachment instead, so that it downloads better:
Brian
Old 3rd September 2002, 10:25 PM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You didn't burn your blade by any chance?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd September 2002, 10:35 PM   #5
BrianGT's Avatar
I guess so... I made all of the external cuts longer then necessary, and they came out looking great with the belt sander.
I have a couple of questions about Thor:
a) will spikes help the sound of the speaker? I have seen no finished Thor TL speakers that used spikes.
b) will the extra .5" on each side of the front baffle change the sound of the speaker that much? I read about baffle sound frequency, but will the sound difference be noticible?
c) anyone have any tips on finishing red oak?
This is my first speaker project, and first time since early high school, since I have worked with wood.
Brian
Old 3rd September 2002, 10:48 PM   #6
I am surprised it's coming so fast. I t looks good too.
I noticed you will have some closed cavities inside the box, you might consider filling them with sand. As to the spikes, or any sort of legs you'll have to decide for yourself by listening tests, because it also depends on the floor the speaker is standing on.
I wouldn't worry about .5" of a difference in size.
I'm not much expert on finishing the oak, but you might use some sort of stain and maybe water based laquer. Maybe the experts at your local Home Depot could shed some advice.
www.audiosector.com
Old 3rd September 2002, 11:10 PM   #7
BrianGT's Avatar
There actually will only be two small closed cavities, which are created on the bottom where the 45 degree angles used in the transmission are. I was thinking of filling them full of something, but I have not decided yet what to fill them with. The bottom part has inserts to make it easily to screw on and off, to adjust the stuffing. I have read that Thor will take quite a bit of adjusting the stuffing to get it to sound optimal. The crossover goes in the base, and I will mount the jacks to the base as well. (my friends are mounting his jacks to the back of the speaker, not the base). I have two weekends working on thor so far... basically 4 - 12hr days, and I am quite satisified with the progress so far. Basically now, I am held back a bit by the lack of clamps and waiting for glue to dry. (have one set of 6 clamps for gluing my speakers, and two friends have their own). My two friends started a week before me, so I was follow their lead, getting it done pretty quickly.
For finishing, I picked up a bucket of red oak stain and polyurethane. I am planning on getting them sanded down with 220 grit paper, cleaning off, and staining, then moving on the polyurethane, applying many coats.
They are quite heavy. The unfinished speaker (mdf covered in the red oak) weighs 70lbs without the base and speaker components installed components. I imagine that they will weigh in around 100lbs each after making a heavy base and finishing.
Brian
Old 4th September 2002, 12:48 AM   #8
fcel is offline fcel  United States
Brian ... enjoyed looking at all the pictures! What made you decide to built this particular brand/model since there are a couple thousand of brands out there? Total cost for a pair (excluding labor cost of course)?
Old 4th September 2002, 02:01 AM   #9
Brian, saw the pictures. You didn't have access to the router?
www.audiosector.com
Old 4th September 2002, 02:07 AM   #10
BrianGT's Avatar
fcel,
Well.. I like the idea of a transmission line speaker, and the Ariel seemed too hard for a first speaker. I looked at a few other designs. Finally, I saw an article in AudioXpress about building Thor, and they rated it quite positively, so I decided to give it a try. Also, I saw several other designs using the Seas Excel speakers, so that bolstered my support for Thor.
I have the article posted at:
http://brian.prohosting.com/nancy/thor.pdf
It was in the magazine in July.
The kit costs $960 without a cabinet from madisound.com and includes everything that you need in a nice kit: assembled crossover (will take pictures later), woofers, tweeter, Nordost internal cable, stuffing measured out in two bags for each part of the transmission line, cabinet jacks (i am not using them, as they are kind of cheap) and sealing material for the base.
Wood is up to you. I paid $14.99 at HD for a sheet of 4'x8'x.75" thick mdf, bought glue, screws and more, which was split 3 ways. As far as tools, I am using my friend's tools. Red Oak was $6 a foot, and I had to buy 18 ft for 2 fronts, 2 backs, 2 tops. The sides were cut from a 4'x8' sheet of .75" plywood with red oak on the outside, which costs $50 a sheet. Don't forget a can of stain and polyurethane.
I would put the overall cost of the project at $1300 for a pair assembled, but you could save quite a bit if you did not use red oak and stuck with plain mdf, but I wanted something that would look nice sitting in my room.
I am hoping that it sounds good.
Brian
First project - runoffgroove Thor. Help needed... 38eighteen Instruments and Amps 4 24th December 2007 06:34 PM
pictures of my last project rbe43164 Multi-Way 17 18th October 2005 12:15 AM
First Pictures of my First Project bjackson Multi-Way 11 6th May 2005 03:33 PM
My Amp Project (pictures for all to see) primalsea Solid State 5 23rd March 2005 09:01 AM
Page generated in 0.12269 seconds (80.47% PHP - 19.53% MySQL) with 11 queries
