I wonder if anyone can give me a tip here and there on my next project being a three way vented system with passive crossovers.
The drivers of choice are scan speak 2405- 9900 as tweter a 18w 3545 for the mids and a peerless XLS 12 inch for the lows. As I have not yet settled on the cabinet design nor on the crossover topology can anyone offer some worthwhile suggestions? The goal here is to have a high end speaker without any need for any subwoofer. Has anyone had similar experience with such a combination?
Nick |
#2 | |
What is a 3545? I cannot see it on the scan website.
Anyway ill say what I say to everyone. If you have measuring equipment you will get a kick *** speaker, if you dont its half a waste of those nice drivers, which are going to cost you quite a bit. Recommendation - build a kit for a two way using those scan units you want, make it a sealed enclosure. Build a sub- stereo subs if you want- this should give you the best results if you cant measure anything. Quote:
Put a PLLXO on the signal to the two way at the frequency you intend for the sub to come in at, this will transform the 12dB roll off of the sealed enclosure to 24dB and match the plate amp on the sub. Are most 24dB?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
Well I have considered using a tweter and two 18ws as used commonly as a configuration in the Rhythm (North Creek) and others but I am quite confident that that would have some low frequency deficiency hence the consideration for the 12'' woofer.
Subs are good for techno type of music (or home cinema) but by definition do not add up any imaging to your system in orchestral pieces. What sort of measuring equipment are you referring to? perhaps it is a worthwhile investment?
Nick |
| FS Scan Speak, Seas,& Peerless XLS Woofers and Mids | bigLG | Swap Meet | 4 | 24th September 2009 01:23 AM |
| Scan Speak 23W sub | Pan | Subwoofers | 15 | 26th December 2007 06:13 PM |
| Drivers for sale - Peerless, Scan Speak, Seas, Dayton, Visaton, Monacor... | atalio | Vendor's Bazaar | 2 | 10th March 2007 01:55 AM |
| Peerless Vifa Seas Scan Speak in car use | jadenlinkletter | Subwoofers | 5 | 16th June 2005 11:47 AM |
| Vifa, Peerless, Scan Speak suppliers in Danmark? | capslock | Multi-Way | 12 | 2nd December 2002 05:38 PM |
| Page generated in 0.08903 seconds (68.11% PHP - 31.89% MySQL) with 10 queries |
